Click for Cross Click for Westport Click for Westport Click for Burger Click for Ocean Alexander
Yacht Trivia Pursuit...
Discussion in 'Popular Yacht Topics' started by YachtForums, Jan 5, 2006.
  1. Arniev
    Arniev Senior Member
    Monterey, CA, USA
    I didn't know the answer offhand to "origin of larboard".
    I did find the answer on the Net:
    From Wikipedia, the free encyclopedia.
    Port is the nautical term (used on boats and ships) that refers to the left side of a ship, as perceived by a person facing towards the bow (the front of the vessel). The terms are also used for aircraft, spacecraft, and analogous vessels. The equivalent for the right-hand side is "starboard".
    A port buoy is a lateral buoy used to guide vessels through channels or close to shallow water. The port buoy is one that a vessel must leave to port when passing upstream if in IALA area A. If in IALA area B (Japan, the Americas, South Korea, and the Philippines) then the 'handedness' of buoyage is reversed!
    An archaic version of the term is larboard. The term larboard, when shouted in the wind, was presumably too easy to confuse with starboard -- both words have two sylables --, and so the word port came to replace it, referring to the side of the ship where cargo is loaded from the port. The term larboard continued its use well in to the 1850's by whalers, despite the term being long supersceded by Port in the merchant vessel service at the time.
    Sorry ... I have no answer to TRY's questions.
    Yep! I did a school research paper on the derivitives & origins of nautical terminology. When I saw "larboard"... it really brought back some memories. Thanks for that!:)
    There is still an outstanding question from TRY...
    "Name a famous yacht, built in a well known European yard, that blew her central propulsion engine during her sea-trials."
    Give name, yard, engine manufacturer.
  3. Kevin
    I'm halfway through Patrick O'Brian's novels... larboard is all I think. LOL
  4. AMG
    Let´s TRY to guess...?
    Can it be Octopussy, she is a pretty famous triple MTU, built by Heesen.
  5. TRY
    TRY Senior Member
    cannes
    No good!
    I didn't imagine this to be such a difficult question!
    Dutch built is right though.
    Triple of course is good.
    MTU is correct as well.
    So, we're still after the name and the yard!
  6. AMG
    Then it could be Al Mirqab with her three 10.000 hp MTU, built at Oceanco in South Africa and Holland...?
  7. TRY
    TRY Senior Member
    cannes
    I knew you could do it, Lars!
    You're next!
  8. kalmeran
    kalmeran Senior Member
    netherlands
    Hm....still don't know, so let me try a deduction : it is not Ecstasea. Sussurro and TheWorldIsNotEnough have four engines. That brings me to the Feadship Detroit Eagle : two MTU's and one central gas turbine (by Honeywell).
    Just a guess, again :confused: :confused:
    OOPS...TOO LATE AND TOO WRONG!!!
    Lars, you were right !
  9. AMG
    OK, a little easier now... (maybe too easy for Kalmeran and TRY).
    What was the project name of Al Mirqab?
  10. kalmeran
    netherlands
    Trick One.........but you suggested it would be too easy, so I'm out of competition ??:)
  11. AMG
    No, you win, but I am out after your question...;)
  12. kalmeran
    netherlands
    Herbert Dahm of Jongert fame : what was the name of his first yacht that he had build at Jongert's??
  13. Rene GER
    Rene GER Senior Member
    Northern Germany, West Coast
    BLACK MOLLY!! she is 17m long. after then the BLACK MOLLY II (Ketch). the next one was the MEPHISTO (hull built by Abeking & Rasmussen in Germany. The rest at Jongert). Then the INSPIRATION and TRUE LOVE
  14. kalmeran
    netherlands
    Very,very correct, Rene!
    Your turn !
  15. Rene GER
    There was an owner who let built some new yachts in an old style. All yachts had the same name, but with the number (I-IV) on the end.
    Name the name of the series of the yachts.
  16. TRY
    TRY Senior Member
    cannes
    Maybe "Borkumriff"
  17. Rene GER
    Not maybe. It's indeed. It's your turn!
  18. TRY
    TRY Senior Member
    cannes
    Easy on a sunday!
    Gimme speed and range of "Golden Shadow"s" fastest tender!
  19. kalmeran
    netherlands
    Her fastest "tender"is her seaplane, the Cessna 208.
    If you mean that one, her speed is 160 kts with a range of appr 600 mls (depending on pay load I guess) ??
  20. TRY
    TRY Senior Member
    cannes
    Very good, your turn!
