Click for Delta Click for Glendinning Click for YF Listing Service Click for Burger Click for CL Yachts
Yacht Serena III sinks off Ft. Lauderdale
Discussion in 'General Yachting Discussion' started by Ken Bracewell, Jan 25, 2016.
  1. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    True. Unless something had been done that negated the water tight integrity of the spaces.
    I'm not trying to make excuses for the crew. But not knowing what happened it could be there is no need to do that. And there really was little they could do.
    Perhaps one of the reasons it went out of class was because modifications where made that would not allow it to stay in class.
    So many unknowns.
  2. BoulderGT3
    BoulderGT3 Senior Member
    Ftl
    I'm not going to hold my breath but I wouldn't be surprised if someone on the boat ends up,talking about it at Treasure Trove or one of the local spots.
  3. Marmot
    You would think that after the beating the crew has taken in this thread someone with mitigating information would have spoken out in their defense ... if there is any.
  4. BoulderGT3
    Ftl
    Remember some of the first stories about what happened with a few of the tender crashes in the Exumas? Navigation and Mechanical issues? Turns out, it was alcohol and darkness issues. In most cases, people will talk and the picture will become clear.
    I still can't figure how so much water got in a steel boat without bells, whistles, alarms or anyone noticing.
  5. Marmot
    I think a large number of people would like to know as well, but a small number of people probably don't want anyone to know.
  6. BoulderGT3
    Ftl
    Educate on how this works on a boat the size of Serena III. Are there pumps in each compartment that send their output to a manifold where it is pumped out of the boat? Probably from the engine room? This eliminates through hulls in the individual compartments? What's a bilge level switch? It means water has gotten to a certain level? Thanks
  7. Pascal
    You wouldn't need thru hulls in each compartment you could have a pipe running the length of the hull to collect the various discharges including pumps and run them aft. Simple. Works.
    I guess "Bilge level switches" are just float switches wired to alarm panels at the helms. Water rises, float switches closes circuit, light comes on along with audible alarm.
    I am in the process of a full refit and repower on my boat. While only 53' I set up each bilge pump on a starboard bracket with a high water float switch, a rule 3700 and a float switch for the pump. Six of them. Each has a wiring harness running to the helm whre I have a custom panel with Green LEDS indicating power on to each pump, circuit breaker, manual switch and red LEDs indicating pump running or high water level. Very simple, cheap as it can be. I can see with once glance if one pump circuit is off, or if a pump is running.i can also be sure than both the pumps and th high water alarms are powered. No worry that an out of view breaker may have tripped
    No, the manifold is on the suction side. generally you have a very large pump (as well as a fire pump (electrical) and engine driven pump that are also generally plumbed to the manifold or pipes) in the engine room, it has a manifold with a valve (like a seacock for each pipe/compartment), then there are pipes with pickups that run to each compartment, You open the discharge valve on the pump, open up the valve(s) of the compartments you want to suck from and turn the pump on.
    Bilge level switch. Yes, generally there is a float switch in each compartment that is wired to an alarm panel, it generally will send an alarm to the panel (usually a Light, some have audible alarms also) that will show high water compartment 1,2,3, etc. It doesn't turn any pumps on generally, but will alert you if you have more than a few inches of water in there.
  9. Capt J
    Yup I was there in the Exumas both when the 38' Intrepid hit the West end of Big Majors, and also when the 27' (forgot the brand, pursuit possibly) drove up onto the rock 150 yards West of Staniel Cay Yacht Club (the Captain was sitting at Sampson Cay on the big boat (A sunseeker predator) and they decided to take the tender to the bar (owner/guest) and drink copius amounts of Vodka.
  10. wayneCCC
    wayneCCC New Member
    Vancouver, BC
    Sounds like you have a very well thought out system there. I would love to get some more information if that's possible? I have 57 foot constellation and plan to redo the mismatch of pump systems I have.
  11. Pascal
    I posted of picture in my hatteras refit thread. What I find critical in addition to the switches and warning lights is also having green LEDS showing that each pump is on, no tripped fuse or breaker. Plus knowing the power feed to the entire system comes straight from the battery bank, not thru some subpanels or junction boxes
    http://www.yachtforums.com/threads/1970-53-hatteras-yacht-full-refit.25658/
  12. Iknownothing
    Iknownothing Member
    Lauderdale
    In addition to the great info from Pascal, I'd suggest splitting a few of the pumps to a different battery bank. Most builders I've dealt with will put the main pumps on the house bank and secondary pumps on one of the engine banks.
  13. Capt J
    I like the way Sunseeker does it better. They have a normal pump like in the photo. Then they mount a higher pump 6-8" above the normal pump, with a float switch, and wired to an alarm. So if the main pump fails you still have a 2nd higher pump that also sets off an audible alarm when it cycles on. Of course you have to have a way for it to discharge.
  14. Capt Bill11
  15. VeeJayR
    VeeJayR New Member
    Dubai
    So did the fins actually break? Any news yet?
  16. Norseman
    Norseman Senior Member
    Palm Coast, Florida
    Amen to that.
    I had 2 Ultra Jr. Switches on previous boat. Worked good, lasted a long time.
  17. Capt J
    They're good switches and I like to use them in shower sumps. However my only gripe is it's a royal pain to test them and the pump, either flood the bilge with water, or tip them upside down.
  18. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Has anyone considered the fact that someone wanted this boat to sink and had the resources to make the plan and execute it?
  19. RER
    RER Senior Member
    Newport Beach CA
    While anything is possible, that's a bold statement. Do you have some reason for suggesting it?
  20. olderboater
    A lot of the scenario really doesn't fit that premise. Not that it's impossible but highly unlikely.
