Click for Westport Click for Burger Click for Ocean Alexander Click for Abeking Click for Cross
Yacht Serena III sinks off Ft. Lauderdale
Discussion in 'General Yachting Discussion' started by Ken Bracewell, Jan 25, 2016.
  1. olderboater
    2012 build
  2. olderboater
    Build started 2007, Launched 2010, delivered 2012. Steel. Built by Brazilian commercial ship builder. Initially ABS classed, but class dropped.
  3. Marmot
    The speed of the whole affair seems a bit peculiar ... unless a major component of the seawater system instantly failed catastrophically one would think there would have been quite a bit of comms going on telling someone about the problem early on.
  4. olderboater
    Perhaps had they had the overdue survey that caused loss of class, they might have avoided this. Class was suspended 9/28 and withdrawn 12/28 for overdue survey.
    The owner is a huge developer and owner of shopping malls.
  5. BoulderGT3
    BoulderGT3 Senior Member
    Ftl
    Built in 2012. If you have access to Twitter there's a good photo of it going out of Port Everglades behind a cruise ship around 4:30PM yesterday. Something went bad in a hurry. Maybe a container?
  6. olderboater
    As to containers, possible, although most speculation is mechanical. Should be noted that there were 25 containers lost in the area off a barge Columbia Elizabeth in December. Oh, and it should be noted also, the operator of the barge, someone we've all heard of related to problems, TOTE Maritime.
  7. Marmot
    That doesn't necessarily mean anything other than the owner decided he had nothing to gain by remaining in class. The cost savings are substantial and the benefits are not always worth the expense and paperwork for a private owner.
    When an owner decides to drop class he will (or can) just not schedule a survey and let the term run its course.
  8. olderboater
    I'm just saying that regardless of his reasons the survey might possibly have avoided this sinking if it was a catastrophic failure of the seawater system or something of that magnitude. A survey one month earlier might have detected the potential issue.
  9. Marmot
    That is extremely unlikely.
  10. Pascal
    Triton reports that in one of the calls, they reported having lost a stabilizer fin
    No idea if report is accurate
  11. olderboater
    I know very little about steel ships or yachts, but wouldn't have thought most of them had stabilizers. Guess I just learned something.
  12. Capt Ralph
    I have seen fin strikes for smaller boats. The shell usually crumbles and falls away. I have also witnessed bent back fin shafts. I have heard about one fin collision the broke the shaft. Properly installed, I can not imagine a fin strike sinking a boat.
    These big boat class thingies (I assume) would also require more H/D installations with breakaway protection in mind vs catastrophic aftermath.
    I also assume these big boat class builds would have Titanic proof bilge holds (unlike that Turk boat in the Med)
  13. Capt Ralph
    Can anybody zoom in on that stern / ER hatch area during the videos?
    We have commented before about an open stern door while under way.
  14. Capt J
    Lots of them have stabilizers just like fiberglass ones.
  15. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    ""There may have been a possible grounding on the way out of Port Everglades and it wasn’t noticed until they were further offshore,” said Sadowicz"
    "Investigators are checking to see if a shaft that attaches from inside the boat to a stabilizer on the bottom may have fallen out."
  16. olderboater
  17. Capt Ralph
    If you cut the channel short and do not stay in the lane till the sea buoy (out bound), you do risk striking a bar.
    I would assume someone would notice a drive or rudder problem before you got that far off shore.
    Unless,,,, The pilot cleared the rocks, turned on the AP, and turned his brain off.
    He may not detect the AP over steering to correct for one rudder loss from a bar strike.
    Then open the stern door to a flooded Laz & engine room.
    Infra red video shows DCv nav lights on, Light plant already dead.
  18. Capt Bill11
  19. Capt Bill11
    The first officer also mentions that they may have touch bottom leaving the Bahia Mar area. Which since I believe they draw 11', is possible.
    And he mentions flooding in a guest cabin. Which could be the location of a stabilizer.
  20. olderboater
