Click for Westport Click for Westport Click for Cross Click for YF Listing Service Click for Northern Lights
Would love to hear pros and cons on 54' & 60' sport yachts
Discussion in 'Viking Yacht' started by Dennis Dotson, Nov 17, 2016.
  1. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    The mans vibrate at under 1200 or so rpms because it is cutting out 1/2 (??) the cylinders for fuel economy. But I don't think it is an issue even at hull speed. Where I notice it is at idle, but for me it is a non issue. When cold they can be smokey but block heaters pretty much eliminate the smoke. I do my thousand hour service every 3 years and the cost is about 14,000. That typically includes all 20 injectors. The parts are expensive 8000 for an intercooler, 1600 for a new raw water pump. When it is rough you are going to roll a lot and be very uncomfortable at hull speed. When fuel was real high I tried the hull speed thing but I think I lasted 30 minutes or so. As a kid I was diagnosed hyperactive, so that may have something to do with that. Not at all trying to discourage you but there may be better choices if you think you are going to run hull speed most of the time. You will be maintaining big hi performance diesel and not needing them. If you go forward with the Viking find out if the torsional couplers have been replaced (25,000) with the silicon ones. Most all will either have it done or will be having it done. You will probably want to paint the boat unless it has been shed kept. I replaced my salon Windows last year, they were leaking. I can't think of the other big issues but ask away and I will try to answer.
  2. Dennis Dotson
    Dennis Dotson New Member
    Louisville, KY
    Thank you, motoryachtlover. That personal knowledge is priceless information. I have stated that fuel costs would not be the deciding factor, but you have brought some reality to my business plan or any theory that I might want to back off to hull speed. And the real information about how you approach your maintenance as well as those costs were also very helpful.
    Now, to get a better number on a projection of annual fuel cost. At cruise I believe the Mans are about 60 gph, is that your experience? I have used the worst case example of predicting my use of 200 annual hours at the full cruise (60 gph) for 12,000 gallons per year. Have you any information of your annual hours used and annual gallons purchased? If I can get some real information on real usage, I can extrapolate some numbers for my use. Any info, no matter how sketchy, would be very helpful.
    I have always loved that boat. More importantly, my wife loves the interior space and separation of the aft deck, the large staterooms and the enclosed bridge.
  3. motoryachtlover
    smithfield, VA
    Yes, the mans and genny at about 2050 rpms will burn about 60/hr. That is running offshore, in the icw it will be less because of no wake zones and such.
  4. Capslingshot
    Capslingshot New Member
    St Pete Florida
    We are doing our survey Nov 30 on a 60 ft cockpit 1999 model, hull survey and Mann engine survey, very excited, any info to look for would be appreciated !
  5. Dennis Dotson
    Louisville, KY
    Best of luck to you. Would love to hear how the survey goes.
  6. Capslingshot
    St Pete Florida
    Will post results as soon as the survey's are complete, thanks
  7. motoryachtlover
    smithfield, VA
    Slingshot and Dennis. Look closely for evidence of leaks around the salon Windows. Mine leaked right above the galley sink. Also the aft stateroom Windows have been subject to leaking. Like I said before the torsional couplers will need to be replaced in my opinion. I would plan on a 1000 hr service if there is no proof that ones has been done within 2 years. Ask the engine surveyor if you have the cast iron oil coolers if not I would have them swapped out. The aluminum ones had a habit of dumping the oil before the alarms would catch it, leading to a catastrophic failure. There are a bunch 30 or so of round recessed lights that on my boat were halogens that I switched to LEDs. That cost about 7000 but the halogens contacts would rust and lose contact and drive you nuts. I had to replace my refrigerator which was a bit of a job. I have had to replace my windlass. The original Simpson Lawrence had a grease fitting that was hidden and I never greased it which lead to failure. Check the deck for areas where the core got wet mine had a spot where the stbd front cleat leaked and had a rotten spot. So sound the deck with a plastic hammer you will be able to hear the difference. That is all I can think of right now but feel free to ask me any questions.
  8. Capslingshot
    St Pete Florida
    Well our survey went great, both hull and engine survey were " better than average " according to both surveyors, only issue was with the davit and it just needs service, a few other minor issues in the galley, close on Dec 21 then move aboard ! home port Stuart
  9. chesapeake46
    chesapeake46 Senior Member
    Congratulations, on a very nice Christmas present for you.
  10. Capslingshot
    St Pete Florida
    Thanks we are excited about the move on board and a lot to learn.
  11. motoryachtlover
    smithfield, VA
    Slingshot as this he boat galati had listed?
  12. Capslingshot
    St Pete Florida
    Yes
  13. motoryachtlover
    smithfield, VA
    I have not seen the boat in person she appeared to be the nicest on the market for the last couple of years. What size mans you got?
  14. Capslingshot
    St Pete Florida
    1050 HP
  15. hbharley1
    hbharley1 New Member
    NJ
    Just had a 60’ Viking CPM yacht survey done with 1050 man engines, surveyor said it was like doing a new boat, couple minor things is all he found. Port running light not working, forward head light not working and documentation numbers not up to standard in engine room. Making settlement in a week on 11/29/24 good luck with your survey.
    gr8trn and motoryachtlover like this.
  16. gr8trn
    gr8trn Senior Member
    OR/WA/CA/BC
    Sounds like a good find. So glad to hear folks are buying boats.
    Mind, this conversation is from 2016, for what it's worth.
