Click for Delta Click for Burger Click for Ocean Alexander Click for Westport Click for Westport
will kelp cutters help with Maine lobster traps
Discussion in 'Props, Shafts & Seals' started by marc foster, Mar 25, 2019.
  1. marc foster
    marc foster New Member
    newport beach
    Thanks David, Philbrooks suggested the exact same thing that you are describing. I did wonder if those triangle shaped blades would work. They do look pretty easy to install and pretty reasonable cost wise. Thanks for the input. Marc
  2. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    I've never needed to stop mid-ocean to clear a trap. They generally break off, and then you can clear them when you get to your destination. You may need to slow down to minimize vibrations.
  3. marc foster
    newport beach
    Agree 100%. I have only attended to a bottom related issue once were we anchored safely or in a slip. The suggestion of diving the bottom in the open ocean just made me think I wasn't Salty enough for this crowd!
  4. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    I had an owner who had a new 56' MY and was complaining of vibration when he would bring his boat down from NC to FL. Started talking about manufacturer's defect, latent defect , all that good stuff that engineers like to hear.
    Arranged to have him haul out in FL, low and behold we have a host of people ready to assess the situation and he is dragging rope/rode from a trap, all the way from NC, assuming it was a mechanical design error! Removed the line, checked the alignment, never heard back again on this "serious manufacturer design flaw".
    Traps are usually coastal, so you most always have the chance to pull into port and assess the situation. But there is that one chance that the fouling becomes more serious and Line Cutters are cheap insurance.
    There was a Nordhavn that had a line fouled on its running gear during the last Transatlantic Group crossing and was successfully cleared at sea. But I can guarantee you that guy was a real waterman, probably had more lifetime hours accumulated "in" the ocean than "on" the ocean.
    I dove in the water 30 miles offshore of NJ once to check the running gear without a wetsuit or anything. I did have a dock line tied to my waist and the mate holding the other end of it. It was FREEZING cold and I wouldn't want to do it again.
  6. GhostriderIII
    GhostriderIII Senior Member
    Newfoundland
    Those are called Kort Nozzles and are very common among us commercial operators. Practically all tugs and push boats have them. Usually used with flanking rudders.
    http://www.kortpropulsion.com/products/kort-nozzles
  7. Ken Bracewell
    Somewhere Sunny
    That's not what the fishermen in Maine have.
    These are literally unsophisticated wire cages around the prop.
  8. PacBlue
    Dana Point, Ca
    Here's a pic:
    [​IMG]
  9. chesapeake46
    chesapeake46 Senior Member
    And that's a really nice one.
  10. SeaLion
    SeaLion Senior Member
    It looks like you'd lose half your thrust with that cage on. Do any pleasure boats use these?
  11. Capt Ralph
    Done rite, it may even help. Notice the last ring a lil wider. If I built that I would of made it a fatter ring, Like a Kort.
    There is plenty of water getting to the prop. If not a high speed setup, maybe not so much air bubbles generated before the water hits the wheel.
    I like this plan.
  12. Beau
    Beau Senior Member
    Beaufort, NC
    Is that a single screw work boat bottom?
    I've seen this before, but I can't imagine putting something like that around my 32 inch props
  13. PacBlue
    Dana Point, Ca
    Usually lobster boats, maybe some lobster yachts, but mainly a workboat thing.
  14. GhostriderIII
    Newfoundland
    That wire cage would fit fine on 32in wheels. My korts were on 60in
  15. Beau
    Beau Senior Member
    Beaufort, NC
    With no keel to use as structure? I cruise at 27-30 knots. Those things would have to attach to my bottom directly.. I couldn't imagine the stress they'd cause. Plus where is my speed and fuel efficiency going - south.
    I'd have to regularly run in pretty junk laden waters to attach those cages to a recreational boat.
  16. Capt J
    You don't want those on a recreational boat. The cages would be for a low speed commercial boat. Kortz nozzles would also generally be for a low speed commercial boat.
  17. Beau
    Beau Senior Member
    Beaufort, NC
    I thought so. Thanks for confirming. If I'm in and around the pots, fish nets or kelp I could understand. But not we guys/gals who run the LI sound and Block island sound mostly.
  18. GhostriderIII
    Newfoundland
    Kort nozzles are made for commercial boats doing less than 10kts in current. The wire cage pictured above would be fine for most planing hulls.
  19. Beau
    Beau Senior Member
    Beaufort, NC
    Single engine maybe - not twins.IMO
  20. GhostriderIII
    Newfoundland
