Click for CL Yachts Click for YF Listing Service Click for Ocean Alexander Click for Abeking Click for Glendinning
When do long distance or round-the-world solo racers sleep?
Discussion in 'General Yachting Discussion' started by Blue Ghost, Jan 7, 2013.
  1. Blue Ghost
    Blue Ghost Member
    The Regina systen in the Spinward Marches
    But if you're under full sail, even in a light breeze, I would think the danger of capsizing or veering wildly off course or something would prohibit you from letting the ship run on "autopilot".
    The fact that people do it is impressive.
  2. Jonza
    Jonza New Member
    Palma de Mallorca
    And if one would like to do the same in a stinkpot, what, except the obvious rigorous ER checks, should one think of?
  3. K1W1
    If you set the boat up for UMS operation the actual time in the ERIC is reduced markedly.
    The only time things would get difficult is when something substantial goes wrong
    Keeping an eye out so that you don't run over any floating debris, radar watch, transfering fuel as needed, other bilge checks.......etc. etc....
  5. CaptEvan
    CaptEvan Senior Member
    Great Lakes
    short sleep
    From what a solo sail customer of mine shared, he has his internal clock trained and timed to awake and check that all is good every 15 minutes. So rather than long rest/sleep periods, he is re-energized by multiple 15 minute time-outs. Anybody else identify with this???
  6. Jonza
    Jonza New Member
    Palma de Mallorca
    UMS would be cool but even w. videocams, exhaust temp/pyrometers, actual coolant/waterflow readings, maybe a permanently rigged IR-gun at the shaft bearings plus the usual plethora of oil/water pressure/temps and amp/volt meters I´d like to do an bi-hourly manual/visual check. One thing´s for sure - the watchberth would become the new master SR.
  7. K1W1
    You might want to read up on UMS to allay your fears.
