Click for Delta Click for Abeking Click for YF Listing Service Click for CL Yachts 99X Click for Westport
What to pay the crew?
Discussion in 'Yacht Crews' started by Fortunata, Mar 5, 2010.
  1. scott49
    scott49 Senior Member
    Woodinville,Washington
    Sorry to get away from crew pay. What I did not under stand is on a 110' why would you need a Mate? I would think 3 to 4 crew would be plenty. Captain, Deckhand, stew, and cook. (maybe cook/stew) To me a Mate is needed when you get up over 140'. I guess I under stand now, knowing Henning said his boat is meant to travel.
    And yes when ever we do longer non-stop trips we put on extra crew.
  2. Pascal
    It s not just the size it s the layout and how the boat is used. If you run longer passages then you need a properly trained and licensed mate
    Well it depends on how a mate is defined. On a 140' + the mate basically is the manager of the deckhand and exterior of the vessel. On a smaller boat the difference is that the mate is or can be technically the deckhand or does it all.......but is licensed......and on a smaller boat.......under say 90' nobody really uses the term deckhand and the person is called a mate and can be licensed or unlicensed and still generally called a mate......
    But like Pascal said, it really depends on the layout and the usage. For example, on a 75' Hatteras MY, I felt comfortable running one person on watch at a time with a crew of 4 for a 2 1/2 day ocean crossing. 3 hours on 9 hours off because you never need to go outside on a weather deck, and the crew quarters and engine room are within 20 seconds from the lower helm if you need to wake someone up (you could even yell from the helm and someone will come up) or do an ER check, you are never outside. On a 109' Johnson I play relief captain on, we have to run 2 crew per shift, because you have to walk on a weather deck to get to both the crew quarters, engine room, and fuel transfer switches. So it takes almost 2 minutes round trip from the helm. I don't feel comfortable running 1 person if they ever have to walk on a weather deck at night for any reason or you cannot wake someone else up without leaving the helm. A long of long range trawlers will have a bunk or bed in the pilot house for that reason, you can run less crew per shift, yet someone is right there if you need them.
  4. Henning
    Henning Senior Member
    Ft Lauderdale FL
    All quite true, but there are issues there, the first a personal thing the second a legal/rules one.
    To me, Mate is a licensed position. There's a heck of a lot of people in the yacht industry with a couple of months experience that call themselves mates with no credentials. Technically, the mate should be able to take the captains position, both legally and physically in case of incapacitation.
    The other is that the RoRs, both COLREGS & US Inland state that there shall be a lookout with no other duties. It has been determined by IMO and in a couple of court findings that a person at the helm does not qualify as lookout because he has other duties (navigating and driving the boat). The issue is a bit muddied in the US because down in the GoM the CG has said that the person on watch may also serve as the lookout in order to allow for reduced manning on oilfild boats. This has been a long standing point of contention between IMO, insurance companies and the USCG 8th district. In practicality, it works out, but when the feces hits the air flow device and winds up in front of a jury, the rules are plainly written so large awards are issued, and insurance companies try to weasel out of paying. It's been kind of a mess in the oilfield for quite a while, and last I heard there were some changes in it to be made.
    I agree that a second person should usually be there, more so at night then the daytime. However, in that position I had 1 person scheduled at the helm and there almost always was a second person awake and keeping the person company. Sometimes on the smaller yachts you just don't have the crew to do that. Honestly to run a two person watch and everyone to get enough time off (which is also a rule when running multiple days) you'd need a crew of 6 of which on some of the smaller yachts you don't have the bunks for or funds. On a USCG documented pleasure vessel, I would assume what the USCG states for manning purposes would be the one to follow.
  6. Henning
    Ft Lauderdale FL
    I agree, I was just pointing out an issue, and the USCG 8th district sees things differently from 5th and 7th district as well as IMO. As far as that goes, it only applies to vessels operating on a COI. What matters to a pleasure boat is what is written in the rules and how a jury is convinced to interpret that. I run single handed and 2 person crew on smaller (<75') boats frequently, it just carries a higher risk.
  7. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    How much compensation for a full time captain depends on many things. The amount of cash per year is important, but as important is if you get along with that person, you trust that person, and the non cash side of the equation. I'm full time on a 65 Sportfish for a private owner, no other crew unless needed. I do everything basically- replace, repair, fix, clean, wax, drive, supply, submit expenses, manage, etc. I have a 401K, health & life insurance, flights to see my family often and as needed and bonuses. I'm well above the 1000 per foot and get along with my owner super. While our schedule is not overly heavy I have little down time to chill. There is ALWAYS something which needs attention. I got my first ticket in 1994, and I would need quite a bit more money to change jobs, and the money part is secondary to me. This is from someone in the category you'd be looking to hire (if I was available), not a bigger boat guy who is out of work, nor a less experienced person looking to move up. I worked in a top manufacturer's yard for three years as a mechanic/captain immediately previous to now, and being able to "fix" the systems on the boat can never be over estimated. Just this week I had a high pressure steering line fail while fishing. I repaired it and restored steering while underway in less than 15 minutes. Marmot, Capt J, Henning and NYCAP all have excellent points, so read them all and come to your own conclusion.
