Click for Abeking Click for Delta Click for Abeking Click for CL Yachts Click for YF Listing Service
What the heck is going on here?
Discussion in 'General Yachting Discussion' started by Capt Bill11, Feb 5, 2016.
  1. Capt J
    Yeah, that's a little rare, but 45 degrees was pretty common. I used to work on a 97' MY that drew 8.5-9' and we used to travel mostly on the intracoastal waterway and in GA and stuff it would happen probably once a day. Also it always sucks you towards the shallow side. The boat would also list at it did this a little bit. You realize it, bring the throttles back to idle or close and counter steer and it turns back.
    I've also had it happen on the 75' Hatteras MY at the turn on the bank in front of Cat Cay at low tide, there it just swung back and forth about 60 degrees total without touching the helm.....till I slowed her down to 7.5 knots for a couple of miles till it started getting deeper as you go East and she tracked straight
  2. CaptNeil
    CaptNeil Member
    East Coast
    Wow it was doing that coming through Devils Backbone? They are lucky to still be on the right side of sea level
  3. olderboater
    This is all something new to my education as I can't imagine dealing with a boat that handled like that.
  4. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    It's really not all that bad. You just have to know the handling characteristics of your boat.
  5. Capt Ralph
    We help on a 92' Mathis-Trumpy on the Ortega river and Jacksonville. MY Innisfail. must be operated dead slow in shallow water. Any +/- slope or mound in the bottom, she will drift sharp to follow or push away, if your not on top of her.
    Less than 10 feet, hang on.
    15 feet she is a queen.
    20+ feet an Angle.
    Some things haven't changed in 77 years.
    ANY deep vee boat and fairly deep draft in shallow water at hull speed will do the same. Some more than others but they will all suck bottom and turn. If you're on plane the same boats won't do it. But take a Westport at 10-12 knots and go through an area with 3' under the keel and it will do the same.
    I know Innisfail, she used to sit on the New River. She's probably the most beautiful Trumpy built.
  7. Capt Ralph
    Up here in my hood.
    She makes most of the failwire home games.
    Sure looks good out on the StJohns river.
  8. Kapn
    Kapn Member
    Annapolis
    Did anyone figure out if it was the Molokai Strait, Hercules in the first posting?
  9. RB480
    RB480 Senior Member
    New Buffalo, MI
    I just witnessed this with a Nordhavn 55 yesterday. It may have been user error but the Captain could not keep her in a straight line at all.
    I was following and radioed to pass in a long straight channel and I was worried I wouldn't be able to get around him.
  10. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Well you learn something new everyday.
    I've run a lot of different boats in shallow water at fast and slow speeds and I've felt them squat, lift and push away from a bank etc. But I've never had one wander from side to side by 30 degrees each way. Yikes!
  11. Capt J
    They tend to wander if they have a keel.....ones without a keel tend to just turn towards the shallow area from what I've seen.
