Click for Mag Bay Click for Mulder Click for YF Listing Service Click for Westport Click for JetForums
Water through air intakes?
Discussion in 'Post Yacht' started by Greg Page, Sep 20, 2021.
  1. Greg Page
    Greg Page Active Member
    Annapolis MD
    Does your Post get water in the engine room coming in through the hull side air intakes? The just installed thru hull that is aft/below the port engine room air inlet has developed a very nice green patina in just a few weeks. It's all on the top faces, so looks like it got a fair bit of spray in the rough running over Labor Day weekend. That thru hull is closed (raw water wash) so pretty much rules out leaks in it's plumbing.
    I'd noticed the wood floor pieces in the same area, outside of the outside stringer, also looked like it was getting wet but didn't put the two together before.
    -Greg
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Sounds like you have your answer and you know what you have to do.
  3. Greg Page
    Annapolis MD
    Was wondering if the Post inlets are supposed to have ducting to keep the water out (like Viking inlets) that could be missing on our boat.
  4. MBevins
    Windsor On. Canada
    I'm a Viking guy , but one would assume there should be.
    Can you access the engine room side of them? If so just measure up covers with top open and install on inside,
  5. Greg Page
    Annapolis MD
    See, yes. Access, not so much. They are up behind the sound insulated engine room side panels.
  6. MBevins
    Windsor On. Canada
    Some boats have the intakes as a separate aluminum or stainless assy that is inserted from outside.
    If yours are like that could you remove them , build a deflector into the backside and reinstall?
  7. Greg Page
    Annapolis MD
    Post intakes are molded part of the hull. Two horizontal slot openings with top inside hull open for air.
