Click for Westport Click for Ocean Alexander Click for Walker Click for Glendinning Click for Westport
Tollycraft vs. Hatteras vs. DeFever
Discussion in 'General Yachting Discussion' started by RossC, Jun 10, 2023.
  1. RER
    RER Senior Member
    Newport Beach CA
    A high strung short lived early attempt to make a high hp (for it’s era) marine diesel in a smaller package. Something that didn’t exist at that time.
    In those days nobody cared about getting only 3000 hours of life out of them. You could rebuild them cheap and you couldn’t swing a dead cat without hitting someone who worked on them. That’s not the case today.
    Availability issues with antiquated parts and very few old timers left who will even work on them.
    Some here will disagree but my opinion is that it’s over for Detroit’s unless you already own them, and know them, and love them. Then by all means keep them running and keep on keeping on. But buying a boat today? No.
    Not for the kind of cruising you said you wanted to do. Bahamas? Loop? Up and down the Eastern Seaboard? Nope.
    Maybe a floating condo and the occasional weekend overnight outing. But not the kind of cruising you described. Sorry.
    In the mid 1970’s I had a 36’ sportfisher with a pair of 6v53 naturals. A whopping 210hp each. And I have the hearing loss to prove it.
  2. RossC
    RossC Member
    Rehoboth Beach, DE
    I'd guess that the Alaskan was pretty much topped out at 8 maybe 10 kts. That was a long time ago. I was in my teens. I remember my grand father occasionally saying he wished he could get more than 8kts.
    My resistance to the Atkinson is that they advertise cruise at 8 and max at 12. So if it takes 660HP to get to 12, how much will it take to get to 8. I'm all for a big engine but someone has to feed it.
  3. MBevins
    MBevins Senior Member
    Windsor On. Canada
    It doesn't work that way, as long as you don't exceed hull speed you'll only use about 36hp or so to push tgd boat, I'm spitballing here but at hull probably in the range of 4gph.
    My two 6-71s (450hp x 2) burn a combined 3.75gph at 7.75kts.
  4. boatpoor
    boatpoor Senior Member
    I've never seen a 453 with a turbocharger but still run two naturals in rough terrain cranes on a daily bases. I've owned them since the mid eighties and neither has had a head removed. I did have a 653 turbo that was a trouble free engine for many years but it was bad about cracking the fuel lines at the injectors early on.
  5. Pascal
    Another anecdote about how nice it is to be able to run from weather. Bigger boat (110’) but same principle.
    Left Morgan’s bluff Andros after clearing customs this morning. Blue skies, no wind… first 2 hour crossing the tongue at 12 kts were great. Then approaching south of Albany the wind picked up thanks to a line of thunderstorms which had popped up over andros, moving our way. Being able to hop on plane at 20kts and stay ahead was great. Eventually the south end of the line fizzled 15 miles behind us by the time we got to Shroud (exumas).
    having the power to get away from weather is worth it.
    cleanslate likes this.
  6. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    I dunno how to do the computations, but...
    I'd guess it takes minimal horsepower to get to and maintain 8 kts.
    Lots more horsepower to get above 10, even more above that to reach 12. Maybe not the full 660, though.
    If the boat was built when the QSC option was 500 hp, if the builder was committed to Cummins power, and if the builder thought 550 might be best for occasional need in real-world applications, maybe the QSM was the next best option.
    You only have to feed the engine as much as you want to. IOW, if you're only using 100-hp most of the time, you're only burning 100-hp worth of fuel during those runs. There's probably a slight penalty for more horsepower than you'd routinely use... but I bet it's not really all that much in the grand scheme of things. (Somebody else here might be able to provide real factoids about stuff like that.)
    Example: We have twin 900-hp engines. 1800-hp total. When we run within our normal comfort zone, "trawler" speed, we're burning between 6-8 GPH total (both engines). Can't (and don't) do that all the time, of course...​
    Charleston toe Rehoboth is an easy trip. I'd say if you like that boat best for all it's other features, and if the price is OK for your budget, you could be boating by this time next week. Without regard to whether the engine is maybe larger than strictly necessary.
    Easy for me to spend your money, though. :)
    -Chris
  7. ranger58sb
    Chesapeake Bay, USA
    BTW, Ross, that "one owner" part would likely be a plus, in my mind.
    -Chris
  8. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    IMHO you are putting too much emphasis on the engines. Given the era of boats you are shopping you could end up with way more headaches than fixing or even rebuilding the engines. Yes, engines are important but they are only one major component with many other things to consider and inspect. You also seem to be looking at a vast array of different type and style boats. As other have suggested, recommend you make a list of must have features then nice to have features. Then you can start to narrow down your target boats into a more manageable range.
    MM3 and JadePanama like this.
  9. SkipJay
    SkipJay New Member
    US
    100% THIS. For the age boats you are looking at I'd be more concerned about maintenance records and knowing the boat was frequently run. I also would not completely write off Volvo. They have made some very solid engines over the years.
  10. RossC
    RossC Member
    Rehoboth Beach, DE
    I'm looking at everything that fits. We were scheduled to look at a '96 Tolly with 3208TA's today but someone wrote a contract on it and beat me to it. We've looked at a few boats this week ranging from 1985 to 2005. So far the '85 is in the best condition by a pretty big margin. The worse was the newest....the 2005.
  11. RossC
    RossC Member
    Rehoboth Beach, DE
    Found a nice Meridian 459 today just walking the dock. Chatted up the owner and come to find out he wants to sell. He gave us the 50 cent tour. Aside from the '85 Albin single screw, it's probably the nicest one we've seen yet. It needs a cut and buff which he said was scheduled but other than that it appears to be a well cared for one owner boat.
    The '85 Albin turned out to be a nice boat. It hasn't had the bright work freshened up this season and there are some paint touchups needed, but Mechanically it's ready to go anywhere. I wish it had 2 engines and wish it had the fuel tanks replaced. Still considering it for the right price.
  12. ranger58sb
    Chesapeake Bay, USA
    We could have considered a 459, but there never was one for sale while we were shopping.
    If it's got Zeus pod drives, you may want to read up on those. I don't remember if those were being built during Brunswick's Cummins/Mercruiser Diesel phase...
    -Chris
