Click for YF Listing Service Click for Ocean Alexander Click for Westport Click for Delta Click for Abeking
Tollycraft vs. Hatteras vs. DeFever
Discussion in 'General Yachting Discussion' started by RossC, Jun 10, 2023.
  1. RossC
    RossC Member
    Rehoboth Beach, DE
    After going over photos, seeing these in real life if like a kick in the nuts, but this one looked good. I was going to send a refundable deposit, but was told it was scheduled for survey. Not sure I'd want to pursue it if it fails survey.
  3. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Remember different buyers have different levels of pain when it comes to a survey. I've seen people walk for relatively small issues, so don't assume a failure if it comes back. Especially since this broker caters to Loopers, most of which are one and done boaters, they want to buy a perfect no issue boat for one year.
  4. RossC
    RossC Member
    Rehoboth Beach, DE
    What I'm finding it that I can spend a ton of money on a late model boat with issues, or I can buy an older boat with the same issues for a lot less. For instance....A newer GB with 3208's or an older GB with leymans or possibly 453's (rare). Both have the same inherent flaws. The clock is just ticking a little faster on the older one.
    I've not seen one good comment about 3208TA's in a displacement hull, but a mid 80's - mid 90's GB will likely have them. Many other boats in the same era also have them. Cat and Cummins become more prevalent as you approach 2000.
  5. RossC
    RossC Member
    Rehoboth Beach, DE
    And being a '76 buyer might have insurance or financing issues, unless paying cash. From what I've been seeing though, when they walk away after a survey, it's usually pretty bad and the owner is not willing to concede on price or make repairs.
  6. Pascal
    It depends. I’ve also seen buyers doing a survey and then realizing the boat they were considering was much more than they wanted. Also some surveyors will note a bunch of cosmetic items, most very typical especially on older boats, but at the end you end up with a LONG survey which will scare off a buyer
    unless a specific engine was really a problem engine, or one for which spares are a real problem, I would keep an open mind about engine model
    MBevins likes this.
  7. Capt Ralph
    The later Cats PAST 31 & 32XX are great. I would still luv an ole 3406.
    Past the old Cummins VT/VMs, the Cummins straight 4 & 6s up are way better engines.
    Cummins has whole engine packages also for re-powers. Factory rebuilt long block and all else new with full warranties.
    I don't recall you mentioning anything yet with Cummins.
    A few years ago I (was mental), worked on a ole Chris Craft with Cummins VM-300s.
    I got lucky. Glad that boat left town.
  8. Pascal
    Back when I repowered my 53 about 5 years ago, I briefly considered 6BTAs. Cost was about $25k per engine with new ZF gear, factory reman with 2 years warranty. I ended up going for the bigger 6CTAs but the B series would be a good option in many trawlers under 50
    A trawler repower is still going to be close to $100k when all said and done.
  9. RossC
    RossC Member
    Rehoboth Beach, DE
    I've looked at a few with 6BTA's CTA's. A few with Cat 3126's. A few with DD671TI and TIB. I would probably consider a 3208 natural. Off the list is Volvo, DD671TIB and 3208TA. On the fence on 671TI. It would depend on the rest of the boat the price. Problem right now is finding a seller that's not hitting the crack pipe. Boats priced at the top of the market with long, LONG lists of years worth of deferred maintenance. A lot of it small items that turned into big items because it wasn't dealt with when it was small.
    The right one will come along.
    Wife found a 42 Azimut flybridge she likes with 3126's. I'm on the fence. It would suit our needs, but I think a trawler is a better fit for us. Seller is high. I've seen 46's for less.
    There is the Albin with a single Lehman 2728T. Nice looking boat. Not a dock queen. Has bow thruster, water maker, stabilizers, new canvas, decent electronics but original fuel tanks. I think it can be bought cheap enough to justify tanks and/or engine should it become a problem. I could spend 4 times as much for something similar with the same potential issues.
    36' Heritage East. Nice boat. Modern electronics. Mid/High time Cummins. High time genset. Might be a bit small but worth checking out. Boat is evidently made by DeFever who never figured out that steel fuel tanks were a bad idea. A 2005 boat should have a number of years before worrying about tanks, but it there.
    I think the DeFever 44 is off the list unless the seller comes to his senses. Not likely this year. Not worth looking at with the current price.
    2005 Atkinson Cape Islander. Nice turn key boat but a whisker above our price cap. Might make an exception after seeing it, might not.
    There are a couple of Tolly's with DD 6V53TI's that we might look at.
    We looked at a 97 Hatt CPMY 42 with 3126's last week. Not a bad boat but the engines are shoe horned in and only has fly bridge controls. I really liked the stand up engine room in the DeFever 44.
    Going to road trip down to Savanah, GA next week and look at as many as we can that check enough of the right boxes.
  10. Capt Ralph
    Now your looking at a Mut.
    Bye..
  11. RossC
    RossC Member
    Rehoboth Beach, DE
    I'm looking at everything. Which one do you consider a mut? The Atkinson is nice and has Nordhvn vibe, but has QSM11 at 660HP. Seems like a lot of HP and fuel for a top speed of 12kts, so that one is off the list.
  12. Pascal
    Mutt is short for Azimut. Stylish, good performing but… how could I put it… quality varies from boat to boat, especially electrical system.
    Personally I would never buy one or recommend one to a customer.
  13. RossC
    RossC Member
    Rehoboth Beach, DE
    Never said I would buy it, but sometimes we do things just to make the wife happy. :) Pretty sure she will talk herself out of it after seeing it.
  14. JadePanama
    JadePanama Member
    Seattle
    In the years you are looking at, I highly suggest you just go in open minded and look at the entire vessel with an open mind. Quit reading everything on the internet about a specific engine model or vessel size/model. Once you get into a budget/year/size you are looking at, they are total snowflakes. Don't rule things out. Find something that suits your needs and check it out.
    You may be surprised at what you find. There are of course better builds to start with, but I have seen so many just write something off because they read something online. Take a real look. If it checks the boxes, who cares what someone else thinks.
    That all said, a Hatt is a fantastic start. The Tolly, while not fully appreciated on the east coast is an amazing vessel...one I would put pretty damn close to the Hatt. Its following is almost fanatical on the West coast and for good reason. In a 40+ year old vessel... its all about how it was maintained over its life. Hell, I have seen Bayliners that are meticulously maintained at 40 years old and serve folks Extremely well. All I am saying is have an open mind and figure out what will suit you well for the next couple (few) years. The cool thing is your are not locked into it. Sometimes the journey of figuring it out is the best part.
    cleanslate likes this.
  15. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    If it helps... we've found it's better to find a boat that checks all your "feature" boxes... and worry later about what engines might be in it. There probably are, of course, some dog engines... either because of initial design, or because of poor maintenance...
    But you're not gonna walk on that engine every day, you're not gonna eat off that engine or cook on it, you're not gonna shower on the engine nor sleep on it... et cetera.
    And all those other features -- that you'll directly interact with -- are what you'll notice, every day aboard.
    Decide whether the engine disqualifies an otherwise "perfect" (?) boat afterwards.
    Ref 660 horsepower: Horsepower that's available isn't necessarily horsepower you'll use. Often. If it takes 32-hp to drive the boat the speed you want to run, then a 660-hp engine will only be working at 32-hp. The extra is just weight, but doesn't hurt much... if the boat features are what you want, and if that boat only came with 660-hp engines anyway. Also... sometimes extra horsepower can come in handy, as in running from a weather front (questionable, anyway), or scheduling to make an inlet in daylight.
    Ref QSM-11: There's a (manageable but) known issue with those, something to do with dry exhaust. Seaboard Marine has quite a tome written about how to deal with that.
    Ref 6BTA's: They have a decent rep, but we had 6CTAs and I believe I'd still prefer those. Wet-sleeved, potentially rebuildable in place if given sufficient work space.
    -Chris
  16. Pascal
    Two more things…
    access to the engines, generator etc is almost as important as which engine is in there. If you can’t easily get to it… it won’t get maintained. If you can’t reach that impeller without crawling and slithering against the engine, have fun when you have to change it when it’s all nice and hot.
    Bigger engines means they won’t be pushed hard and last longer. When you’ll can cruise at 50/60% power, not only do you have reserve power to get out of weather or make it thru a difficult cut in daylight but your engines will last a lot longer than if you constantly cruising at 75%.
  17. RossC
    RossC Member
    Rehoboth Beach, DE
    Thanks guys. I really am looking at everything that fits less than 300K within a days drive. I agree on the engine room. Most of these boats, especially the MY's have very tight engine rooms. I wouldn't even call it a "room". More like a compartment. I wouldn't rule out a nice boat because of it, but it is a consideration. I'm not a tiny guy and I like to be proactive on maintenance and will be spending some time in the engine room.
    I'm pretty open to most brands and engines, but not crazy about overpowered trawlers. 3208TA's in a 42GB burn around 10 GPH at 8kts. Same boat with Lehmans or DD 453's is 4-5 at the same speed. Also don't like that the 3208 can't be rebuilt in-frame. The Atkinson is a cool boat but ad states max speed of 12kts with 660HP. That doesn't sound right. My grand parents 48 Alaskan Pilothouse had 135 Lehmans and did 8kts all day long.
    Some of this has to do with the available inventory and my patience to wait for the right one to come along. I'm hoping some of the ones on my short list that went under contract back out. A broker said that it is definitely possible. They are seeing people back out because of financing or insurance issues and just getting cold feet because of the economy.
  18. boatpoor
    boatpoor Senior Member
    Ross, I sent you a PM.
  19. RossC
    RossC Member
    Rehoboth Beach, DE
    Guys....Any serious complaints about DD 6V53TI's? I did a forum search and this thread is the only one that came up. Ad says they are rated at 370HP. The 2 Tolly's on my short list have these engines. Both with around 2500 hours. Just a guess, but probably run more like a trawler than a flat out sport fisher.
  20. ranger58sb
    Chesapeake Bay, USA
    You must be a better shopper than I am... all these boats you're finding that I've not seen in YW or BT. Looks like a nice boat.
    Is it the max 12 kts you object to? Or the 660-hp? Or both? Or the single diesel, instead of twins? I wonder how many of those 660 are actually in use at 12 kts? (And I also wonder why the builder didn't choose a QSC.. but I dunno that hull, so I'm not a great critic.)
    Assuming LWL is 43' (probably not), that would mean maximum theoretical hull speed might be in the region of 8.8 kts. It can take lots o' horsepower to push water beyond that.
    That 48 Alaskan was with twin 135s? Would it do 12 kts at all? 10?
    -Chris
