Click for Nordhavn Click for YF Listing Service Click for YF Listing Service Click for Northern Lights Click for CL Yachts
Thruster installer needed
Discussion in 'General Yachting Discussion' started by MBevins, Feb 6, 2024.
  1. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Yes, the remote is a given and part of the spec. Motoryachtlover nailed it exactly.
  2. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    I can see why a stern thruster would be much easier in your situation. Whereas splitting the gears works, you have finer control and can feather a thruster much better than just using the wheels. At least that’s been my experience.
  3. MBevins
    Windsor On. Canada
    I agree, but in my case it's really about holding station in a lock or holding the boat to the dock while securing.
  4. sam356
    sam356 Member
    Great Oaks Fairlee Creek MD
  5. Cpt Sous-Leau
    Cpt Sous-Leau Member
    USA, Earth
  6. MBevins
    Windsor On. Canada
    I hear yah, my price from then was the same price range.
  7. Cpt Sous-Leau
    USA, Earth
    I just took a gander through the jetthruster site. Would need a dual pump and four ports for boats over 50' with a fair amount of cabin height(most power yachts). Getting pretty pricey just for the materials. Labor would be higher as well. Looks like a very nice setup with the jet pump, but the cost is a bit high.
  8. MBevins
    Windsor On. Canada
    I to looked into, I couldn't get follow-up to my attempts to put a package together.
    I decided I didn't need to work that hard to spend money.
    So I found a guy that cares.
  9. Cpt Sous-Leau
    USA, Earth
    My dart board said about 20k Euros for the bits, and maybe 90-100 hours installed for the dual 90Kg. Lotta plumbing and lotta batts too.
    My dart board for the Side Thruster seems to be $5600 for the unit delivered to the shop, and about $7500 install, maybe a bit less if I have the bottom job done at the same time.
  10. MBevins
    Windsor On. Canada
    Your dart board is pretty close.
