Click for Burger Click for Delta Click for Walker Click for YF Listing Service Click for Abeking
Tender setup? Size??
Discussion in 'Post Yacht' started by PtJudeRI, Dec 16, 2018.
  1. jrp4783
    jrp4783 Member
    Detroit, MI
    Good eye! Yes - Old Club
  2. PtJudeRI
    PtJudeRI Senior Member
    Pt. Judith, RI
    So measurements taken yesterday. From the raft to the aft edgeof the pulpit is 13'6". Width is no issue at 12' inside the walk-around. So I'm thinking that the tender can only be 10-11' if I want to keep my liferaft where it is? How much length does the motor up usually add to the tender?
  3. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    If you get and inflatable rib boat, none to little...the boob tubes, or tube ***** ( that's what I call them) :) will project as far or further back than the motor. If you have to tilt the motor up at bit to load then 8-12'' perhaps. Then again maybe none at all. Depends on the chock height/shaft length.
    If you find the older clean 11' Whaler, which is the one you should find/get, then around 10-16'' with a 10-20 Hp motor.
