Click for Cross Click for Glendinning Click for Ocean Alexander Click for Perko Click for Burger
Tender garages
Discussion in 'Center Consoles, Tenders & Dinks' started by orion, Apr 27, 2006.
    Thanks Kevin. Already done. YachtLuver... be careful. ;)
    ok, what is wrong now, i seem not to know what to do when posting something, i am getting the feeling now that i cant post anything now without it being wrong..:(
  3. Kevin
    Think of it this way: If you were invited to visit Paul Allen aboard Octopus, would you wear Linux t-shirt? :D
  4. YachtForums
    .... :D I haven't laughed that hard in while. Thanks Kevin!
  5. YachtForums
    Ron,
    It's not your fault... it's my fault. There are certain sites we don't allow links to, yet there is no list of these sites posted for reference. So again, it's not your fault and you have done nothing wrong.
    I have some very good reasons for this, but this is not the place to discuss them. We ALL appreciate the info you bring to YF and I'm really glad you're a member. PM me for an explanation. There's some history behind all of this.
  6. Yacht News
    Which is better?
    Which is better for tender storage...depending on what angle you are looking at it from. Whether for esthetics, praticality and maybe classification. Storage in the stern/transom area with a stern door...that seems to be popular with the smaller yachts. Then storage with aft side door launch such as with Utopia, Sarah, Carinthia VII etc..this is popular with mid size yachts...there is also the stylish storage position behind the bridge such as with La Masquerade, the former Alfa IV, all the Blue Moons and so on.... Or the less used bow doors..such as on Callisto and one or two others.
    What do you guys think...
  7. KCook
    KCook Senior Member
    Phoenix
    The doors in the side of the hull do look VERY cool. And really open up huge areas of the hull for stowing tenders. But I can't help wondering about the practicality of these doors. And what their presence does to the integrity of the hull structure.
    old fuddy Kelly
  8. OutMyWindow
    OutMyWindow Senior Member
  9. KCook
    KCook Senior Member
    Phoenix
    A bow hatch makes a lot of sense to me ....
  10. EnigmaNZ
    EnigmaNZ Member
    New Zealand
  11. AMG
    Hmm,
    I think the designer has said that he got his inspiration from the Baltic Icebreakers and combined it with a more yachtlike styling;
    http://www.tugboatlars.se/Varma.htm
  12. orion
    orion Senior Member
    Newport Beach, CA, USA
    Limitless have a very nice garage to her wooden runabout.:cool:
  13. KCook
    KCook Senior Member
    Phoenix
    Sorry to be a timid soul, but hull cutouts that huge make me wonder.
    Kelly
  14. Codger
    Codger YF Wisdom Dept.
    Western Canada
    Are you concerned with structural integrity of the complete vessel?
    When closed and locked, if done properly, there shouldn't be a concern.
    When open, the potential twisting loads can be easily transferred to other structures internally.
    Or are you wondering about something else?
  15. Yacht News
    Mabe a huge side swell with the door open is whats bothering Kelly.
  16. KCook
    KCook Senior Member
    Phoenix
    All of it. I'm NOT a structural engineer. But I'm not buying the "loads can be easily transferred to other structures internally" either. If it were my design I'd either put that big runabout in thru a stern door or up on deck.
    Kelly
  17. Garry Hartshorn
    Garry Hartshorn Senior Member
    I have to agree on that
  18. Yacht News
    I agree though...even though both installations have their pros and cons. If you store on deck you have to worry about sea spray and exposure generally.....Having side doors are more of a risk than anything cuz if the weather turns bad and some water comes aboard then you could have a problem..That's why i always see Octopus shut back her side doors almost immediately after she launches something. You also have the issue of the weight loads on the structure at that point in time..
  19. Codger
    Western Canada
    There are two concerns then?
    1) water ingress through a large door. The garage behind the door is above the water line. The garage itself has it's own internal door which should be closed. Worst case would be a wave flooding that one room, clearing out it's contents, draining out and hopefully leaving a few wet crew behind. If the internal door is left open then I'd agree that there could be a problem.
    I don't know this for a fact but I'd bet that those garage doors don't get opened up in any kind of a sea anyway.
    2) structural integrity. When the garage door is closed and locked it makes very little difference to the overall strength of the structure. As an example: next time you are out at an airport take a look at the underside of an aircraft wing. There are quite a few access ports used for inspection/lubrication. Those panels are just held in by screws or dzus fasteners which only connect to the skin, not to internal frame structures. If you removed all the panels and put a load on that wing it would still stand up to a goodly percentage of it's specified failure load point. With all the panels in and fastened the wing will meet the load failure point.
  20. KCook
    KCook Senior Member
    Phoenix
    I believe this door is several magnitudes larger than those access panels on the underside of an aircraft wing.
    Kelly
