Click for Ocean Alexander Click for YF Listing Service Click for Cross Click for Nordhavn Click for Ocean Alexander
Teak Deck on an SF
Discussion in 'General Sportfish Discussion' started by Berean, Oct 15, 2012.
  1. P46-Curaçao
    P46-Curaçao Senior Member
    Will check that, my steps are 3/4" thick, and feel very strong...
    Not after they've been baking in the sun and become flexible.
  3. P46-Curaçao
    Will give it a try and let you know!
  4. Caltexflanc
    Caltexflanc Senior Member
    North Carolina
    That's what I did on my pulpit, used the Awl Grip glass beads and it turned out and functions well.
  5. Bill106
    Bill106 Senior Member
    Beaufort NC
    Absolutely! You can mix them into just about any paint. If you're brushing or rolling the broadcast method will give you a more uniform pattern as overlaps will double up on the particles. Brush/roll a coat, sprinkle evenly over while still wet, allow to dry and blow off excess and brush/roll another thin coat to seal.
  6. Berean
    Berean Senior Member
    Sarasota FL
    Very cool!
  7. Berean
    Sarasota FL
    Thanks Bill!
    You don't want them in the last coat, they will wear through or off too easy......the coat before the last coat.
  9. Caltexflanc
    North Carolina
    Exactly.
  10. Berean
    Sarasota FL
    Got it.
  11. Capt J
    You can also prep the teak properly and paint it white with Awlgrip if you so choose.
  12. Berean
    Sarasota FL
    I might eventually do this along with a "debrowing" for a more clean look.
