Click for Cross Click for Burger Click for Ocean Alexander Click for Glendinning Click for Northern Lights
Stretching Generator Oil Change Interval
Discussion in 'Generators' started by DOCKMASTER, Jul 21, 2025.
  1. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Where are these globe impellers sold?
    The mains as well as the Gen?
    My pumps are a royal PITA to get to so anything that pushes that out is a bonus
  3. rtrafford
    rtrafford Senior Member
    Vero Beach
    Yes, I used the search and inputed the make of the generators and the part number for the sea water pump (provided by NL in their manual).
    Then I took the part number from Globe (075) and searched the net, bought them from Defender, I think...
  4. Nomads
    Nomads New Member
    Fiji and Marshall Islands
    You could look into bypass oil filter system, such as Amsoil(no affiliation) to extend oil change interval.
    I tried them back in 2008 in the early days when they came out on a set of 12v71's, pulled out into Ny harbor and port main engine was overheating and not pumping water. They had a tendency to bend too much back then, switched back to traditional impellers and never looked back. Things might be different now, but I tend to stick to OEM unless given a really good reason not to.
    Yep, back then the veins flew and could not pump much/any water on small to 250HP engines. I have been avoiding them since.
    UNTIL another try in the last couple of years on NL gen-sets. We were going thru rubber impellers just to fast and had to experiment. Seems to be our fix.
    I don't know they offered big HP impellers, they don't now. I do look forward to more small impellers to experiment with.
  7. rtrafford
    Vero Beach
    That's the experience Ive had with NL setups. I was going through more impellers than rum aboard.
  8. Capt Ralph
    Good thing I haven't been onboard. That comment would be bass ackwards. :p
  9. Capt J
    I had that happen years ago with a 20 kw Westerbeke, it ended up being too much head pressure because the owner never cleaned the heat exchanger. I haven't been around a NL in a very long time.
  10. rtrafford
    Vero Beach
    Could be that the issue was always a bad pump from the factory, caused the "impeelers" to fail. Later the pump took a dump, too. Always just pinned that to NL. Who knows. Picked up four new Globes, and next impeller changes take place in around 100 at the next oil change...we'll see...
  11. Capt Ralph
    We noticed issues after installing 3 new sets on two different Hatts.
  12. Capt J
    No, it happened in NYC. I popped it out while a mate ran slowly up the Hudson on 1 engine, popped in a Jabsco we had, and continued to do the entire Great Loop back to Fort Lauderdale without any impeller issues. The material the impeller was made out of was too pliable and sometimes they couldn't prime. They probably changed the formula since then.
  13. rtrafford
    Vero Beach
    Ahh, no, I meant my own experience. But I change the impellers on the mains frequently, and I stick with Jabsco on them. I swap the mains on 300 hours and generators on 500.
  14. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    The manual that came with new 15kw home back up gen, I believe with Kubota diesel, warned to NOT use synthetic as it may cause rings to not seat. Nothing said about using or not, after its early days so I've never used any.
  15. rtrafford
    Vero Beach
    I’m old school. I don’t try to stretch the oil life. Regular oil changes are the cheapest bill to pay as compared to alternatives of premature aging and failures.
  16. Capt Ralph
    That is what we concluded on ourselves. Break in oil.
    Later Shibaura engines marinized by Luger, Onan and earlier Kubota engine manuals just spec CH or CK-4 oil.
    Nothing in the owners manual says anything about synthetic.
    One of the local reps got concerned when we were talking about oils in our new NL equipment. NL support called us the next day.
    It is all CK-4 these days. I am a true believer that the synthetic oil works as good or better and more forgiving.
    I also remember MAN engines specifying only certain synthetic oils from day one.
