Click for Delta Click for Burger Click for Westport Click for Cross Click for Westport
Sportfishing boats for cruising?
Discussion in 'General Yachting Discussion' started by Altitude, Jan 11, 2023.
  1. bayoubud
    bayoubud Senior Member
    Florida
    The 54 and 62 Offshore are one of my favorite pilothouse models.
  2. gr8trn
    gr8trn Senior Member
    OR/WA/CA/BC
    Nice to hear you are shopping, I agree prices are still COVID and economy inflated, they should quiet down a bit in a year or two. Good news, that give you a year or two to ramp up your fitness, restorative sleep, nutrition plan to be in better physical shape at 60 than at 58. No worries mate!
  3. Norseman
    Norseman Senior Member
    Palm Coast, Florida
    Don't think it is too tall, just right in my book.
    bayoubud, GPO and MBevins like this.
  4. Pizzazz7
    Pizzazz7 New Member
    Sozopol
    My view is that there are, generally speaking, three major types of motor boats that can be used for cruising with different intrinsic (hull) characteristics:
    1. Motor yacht... planing hull, 12-15 degrees deadrise, fast, sleek, can cruise economically at 20 knots and do 30 knots if conditions allow. Fuel economy depends mostly on displacement and deadrise angle, you can get 1 nmpg with a 40-45 hull, half that with a 60 ft hull (at 20 knots). At displacement speed you can get 1.5-2 nmpg if lucky.
    2. Fishing optimized boat... planing hull, 20+ degrees deadrise, some people like the look, others do not. Higher speeds that a motor yacht. It is as good as it gets in rough sea but when the see is rough, it is rough, period. Fuel economy is roughly half of the motor yacht, some of this comes from the higher deadrise but also from being built to a higher standard (heavier).
    3. Trawler... displacement (older) or semi-displacement hull (newer), cruises at three times lower speed but not necessarily more economical because it is a lot heavier than a comparable size motor yacht. It has more amenities, optimized for people who live on the boat at anchor (vs. the motor yacht where people hop from one marina to the next and eat at restaurants most of the time). You can run the semi displacement hull to 17-20 knots but it is not optimal, fuel consumption is high and it is not designed for that.
    Now, you can use any of the boats for any activity with some strange results. You can cruise on a SF at 30 knots in good weather and cover 500-600 nm overnight, including refueling stops. That is impressive but will cost you a lot of money and comfort. Once I cruised on the Riva 48, covering 550 nm over two days, it was fantastic. On the way back we covered one stretch of ~350 nm in a single 24 hour period in force 6 weather. It was a miserable experience that no one on board wants to repeat. I assume that on a trawler, it would be more even, steady, slow, less exhilarating and more comfortable. You can also fish from a motor yacht but you will not be satisfied with the experience. So, I suggest you run these scenarios in your mind and think about how you want to use the boat, specifically do you mind the higher fuel consumption of the SF for cruising?
  5. Trinimax
    Trinimax Senior Member
    Depending on the budget, the maritimo 60 may be a good option. Sportfish like profile, enclosed bridge with internal stairs, wide side decks with high bulwarks/ rails for easy walk to the bow. the 60 maritimo also has failry good speed reportedly cruising mid 20's and topping over 30 kts with 1000 hp c18 cats, and with 1700 gallons of fuel the range should be adequate. the cockpit on the maritmo is more geared towards cruising, but light sport fishng could easily be done.. Even the smaller maritimo models, 48 and 52 appear to have the wide side decks and internal stairway access to the enclosed bridge.
      81.3 KB
    bayoubud and wiredup like this.
  6. GPO
    GPO Member
    Ladysmith, British Columbia
  7. GPO
    GPO Member
  8. Altitude
    Altitude New Member
    Nc
    Sorry I actually meant the outer reef
  9. Eddieclemons
    Eddieclemons Member
    Nashville, Tn
    I just wanted to spend time as close to the water as possible. We definitely don't have the room of a MY or Trawler. Definitely could have enjoyed a lower helm once or twice. We burn a little less than 10 gallons at 9knots or so. Cruise around 20 knots burning 45-50. I love the ability to get up and run when needed.
  10. Eddieclemons
    Eddieclemons Member
    Nashville, Tn
    FYI, my wife wasn't a SF fan for all the mentioned negatives, but she now loves to get back to the slip asap after a long day. I attached a cockpit setup when she is in charge.
    fredn likes this.
  11. CaboFly
    CaboFly Active Member
    Seattle
    My 48 Cabo has a 11.5 degree transom deadrise. I don't get to 20 degrees until just fwd mid ships. Where my transducers are mounted just ahead of each engine is just 18.5 degrees. From a fuel economy perspective for me it is best @ 700 to 900 rpm which is 7 to to 9 knots burning 4 to 8gph. After that you are on plane getting .5 nmpg. For me that is 1825 at 30 knots burning 55gph with a 65% load.
  12. dewald
    dewald Member
    Treasure Island, Florida
    The setup in the cockpit my wife would say my kind of girl.
    fredn likes this.
  13. CWV
    CWV Member
    Chesapeake Bay
    We use a SF for cruising and long-distance travel from Bahamas to Canada, including the loop.
    I value the speed, handling and ride quality 90k lbs and 2800 hp gives us, particularly with weather or when we have self-imposed deadlines. I also love the sexy lines of the boat’s style - - but the cost as others have mentioned comes in fuel burn above 8 knots and a sometimes uneasy feeling when getting up to the foredeck with heavy fenders / lines, etc., but the use of headsets has improved communication to the point we work through it better than yelling back and forth these days :)
    For anyone seriously contemplating that Viking 61EB at the stuart show, send me a PM. I’ve been all through that boat a couple years ago after it returned to the states and HMY was selling it out of palm beach gardens
  14. Pascal
    One issue with SF which I forgot to mention earlier on is boarding from a fixed dock. Many think the boating is a perfect world with floating dock but it is not the case. Many marinas on the east coast and Bahamas (if not most) have fixed docks and watching folks getting on or off a SF can be very entertaining :). It s big step down from the dock… and a tall climb from the boat…. We see it all the time in the Bahamas.
    MY and trawlers have higher deck that are much closer to fixed dock heights
  15. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    That must vary by location. Really high fixed docks?
    We're at a fixed dock, and we can't board over the side of the boat at high tide... have to step down from dock to swim platform. And then we can't get on/off from the swim platform at low tide, have to go over the cockpit coamings. And that's with only a normal 18"-2' tidal range...
    Our cockpit coamings are slightly higher than a real sportfish or convertible, though...
    -Chris
  16. Capt J
    It's incredibly easy. The side of a SF comes up greatly to the bow, so somewhere along the side, it's always even with the finger pier. That's unless you're in a crappy marina with only 10' long finger piers.
  17. Pascal
    and then going forward you have a rail in the way…
    not just an issue in a slip with finger pier but when alongside in marinas like Staniel for instance.
  18. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    Here is a picture of a SF with stairs to the bridge.
    chesapeake46 and bayoubud like this.
  19. Eddieclemons
    Eddieclemons Member
    Nashville, Tn
    Oh my, that is nice!!
  20. CaboFly
    Seattle
    I believe that is a 50 Viking and one of only a few built with integrated stairs.
    Only production builder I know of that offered integrated stairs was the 48 Tiara Flybridge which is a good cruising boat IMO.
