Click for Burger Click for Abeking Click for Ocean Alexander Click for Northern Lights Click for YF Listing Service
Soot exhaust leak
Discussion in 'Technical Discussion' started by Dan balmer, Jan 5, 2020.
  1. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    You could get a point and shoot thermometer. Set a base line, compare P and SB. Check them once in a while at similar operating temps. If it starts getting hot around the edges of the insulation or develops (much) hotter spots you can assume something's going on in there....
  2. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Was working on my Yacht today ...40 year old Ocean Yachts that is :).
    Took the semi-soot stained blanket off my Dawg and was able to pull off chunks of old iron from the bottom of the original J&T cast below at the round flange connection to the Turbo exit side .
    Do you think it's time I change it out ?! :rolleyes: 40 year old elbow.
    Yes I did the starboard side three years ago.
    My boat is a restoration in use vessel. Keep on using it and replace things as I go along. I love ito_O
  3. Beau
    Beau Senior Member
    Beaufort, NC
    Thanks. Will do. I used to casually inspect the systems. I will now examine them more closely. Thanks Dan for raising the issue.
    Yes, replace. If you're getting soot on the blanket you have an exhaust leak. If chunks of old iron are falling out of the cast elbow, it's shot.
  5. mapism
    mapism Senior Member
    Sardinia
    I'm also a fan of the "if it ain't broke..." principle, generally speaking.
    But removing the shrouds after 22 years for a decent visual inspection sounds pretty reasonable, to me.
    Beau
    Are your risers cast iron or stainless?
    I've always noticed nice stainless cans on the MANs.
    You may see a water leak before an exhaust leak with the shinny dawgs.
  7. Capt Ralph
    Chunks of iron or just bigassed rust flakes?
    I remember a member a while back that replaced a iron mixer with the updated stainless unit but had a hose connect problem. Before you take it apart, take a bunch of pictures to your J&T shop to make sure it's a real plug & play.
  8. Beau
    Beau Senior Member
    Beaufort, NC
    They are stainless and I see nothing evidence a leak.
  9. Capt Fred
    Capt Fred Senior Member
    Long Beach CA
    These guys make a replacement in cast stainless steel elbow that looks much superior to the original cast iron or a welded stainless mixing elbow and very inexpensive compared to the competition. https://hdimarine.net/
  10. Beau
    Beau Senior Member
    Beaufort, NC
    On their opening page they are showing bronze elbows for a SS mixer, Is that good? Mine are all SS, if my memory is correct.
  11. Capt Fred
    Long Beach CA
    I'm not the expert there but it comes with a real thick gasket and I don't think that joint is wet except when running. I do share your concern and wonder why that part is not stainless. Probably worth asking their opinion and others on yachtforums will likely offer advice.
  12. Capt Ralph
    Yours was made for your engines with the boat install in mind. All custom welded stainless.
    HDI makes replacements without any custom thoughts. Including not knowing what hose size will be used at the dump can or what direction the hose needs to be pointed.
    Bronze will work just fine with the cast stainless.
  13. Beau
    Beau Senior Member
    Beaufort, NC
    good to know
  14. cleanslate
    Cherry Hill, NJ
    What's a dump can? Other than the one we all already know about....:eek:
    What's it purpose such as inline DD71s? and others?
  15. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    Far from an expert my understanding is that the main function of the dump can is to cool the exhaust gasses so they can pass through the fiberglass tubing and “rubber” hoses as the exhaust exits the boat. I replaced mine as the yard was in there doing major work and the yard said the spray ring holes were becoming corroded. They said I had about 5 more years but I replaced them since access was available. I never saw any evidence of soot on mine.
  16. cleanslate
    Cherry Hill, NJ
    Ok , so all combustion gas is passed through the turbo and out the elbow? With the elbow being water jacketed with a ring collar with holes in it spraying at the exhaust gas after the turbo within the elbow... ? This is where all the the cooling water comes from out the stern exhaust pipe ? The only source of water out the exhaust pipe ?
    I do know if the elbow cooling water holes get clogged up you can have a big problem and or fire from all the heat generated there.
  17. Capt Ralph
    Usually before the hoses and tubes start melting and burning, somebody noticed the engine temp going up.
    If raw water does not go thru the whole engine systems, it over heats.
    This is the big question if water is coming out your exhaust, one; pumping water? two; pumping all the water? If the riser, mixer, dump can is restricted, the motor gets warm/hot/overheats.
  18. Beau
    Beau Senior Member
    Beaufort, NC
    Check out the website at post # 29 for a visual of a replacement set up?
  19. mapism
    Sardinia
    Nope. The main function of dump cans is to silence the exhaust.
    The possibility to use rubber hoses after the dump can is just incidental, sort of.
    In fact, also u/w exhausts (where there's no can) have at least one section made in rubber, to avoid transmitting engine vibrations to the hull.
    Of course, that can only be done after the raw water re-injection point, because the initial dry section right after the turbo can get red hot.
    Which is the reason why it's covered with insulation, but that applies to both u/w and can exhaust systems.
  20. Capt Ralph
    Are you referring to a water-fall or flooded muffler can? Confusing it with a riser/mixer/dump can?
