Click for Abeking Click for Ocean Alexander Click for CL Yachts Click for Delta Click for Abeking
Slow acceleration, Black Smoke
Discussion in 'Engines' started by wetline, May 1, 2021.
  1. Capt Ralph
    Exhaust back pressure after the turbo.
    Have you thought about getting a rear tech out there yet?
  2. wetline
    wetline New Member
    new London
    I contacted three different mechanics ,they're all backed up for several months.
  3. NYCAP123
    How many hours do you have on that motor?
  4. wetline
    wetline New Member
    new London
    about 950 ish its a 2005 all manual no electronics on the engine
  5. wetline
    wetline New Member
    new London
    I keep thinking it's the fuel pump over fueling,
    its governed by turbo boost pressure from the intake manifold
  6. NYCAP123
    I'm wondering if you don't need a valve adjustment.
  7. Capt Ralph
    Capt Fred did mention something close to that.
    In the old days of Detroit fuel modulators, it would cause a similar problem just on fast acceleration.
    As boost did come up, the smoke cleared.
    You mentioned the injectors were checked, does that mean popped and matched?
  8. wetline
    wetline New Member
    new London
    Yes all four injectors popped at 3,000 pounds pressure with good atomization
  9. Capt Ralph
    I missed this post.
    And sorry about the interruptions.
    In watching the wastegate, see if it is operating at all.
    It should start in the closed position. if it starts to move and your making smoke, try to push back on it a lil.
    It is of course going to be hot.
    Also, watch for it moving in rythem with that bouncing boost gauge.
    Getting back to the fuel pump / governor over fueling.
    Hard for me to explain but I'm still thinking not.
    If we poor the fuel in, the expanding exhaust gasses should still come to the rescue and spin the turbo up and offer the air required. Big circle of parts working together.
    Throttle delays and servos were designed to slow the fuel dump down a lil to keep the intermittent black smoke belch down. Even without these ad-ons, a not so fast throttle hand would do the same.
    So, I'm still on the turbo / wastegate assembly followed by restricted exhaust.
    Now, the techs, you did reserve one or all?
  10. Capt Ralph
    Ah, You had the turbo off?? Was the exhaust manifold and the riser can clean/clear? No carbon building up or clean, just covered in soot?
    Soot in both directions? Both wheels dirty? Any stains or nics?
    Shopping for a rebuilt turbo chunk yet? You may not need the whole thing, some tubos sell with just the center chunk.
