Click for Abeking Click for Delta Click for Westport Click for Northern Lights Click for YF Listing Service
Should I buy a boat with IPS drives?
Discussion in 'General Yachting Discussion' started by Max Waibler, Apr 29, 2020.
  1. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    My outcome: After all the Volvo and IPS research, I was eventually able to go view two of the available boats. Decided not to pursue, not because of the engines/drives (although one of the boats was in better mechanical condition than the other) but rather because of some layout issues that just don't suit our requirements. Nice boats, though.
    -Chris
    Would we be correct to assume the layout issues were a matter of personal tastes rather than space since IPS generally gives increased living space over shaft driven boats or did the system somehow interfere with the layout?
  3. mapism
    mapism Senior Member
    Sardinia
    I've just seen the very simple question in the thread title, and I thought it deserved a very simple answer.
    In which case, my own would be no.
    Then again, I'm not sure it makes sense to expand further.
    It seems that the OP disappeared, after throwing the rock into a pond...
  4. NYCAP123
    If one person asks a question how many have the same question but don't ask or just look for the answers already out there? It's good if the OP gets his question answered. Maybe he'll come back after he makes his choice and enlighten us further. But how many will learn from the thread in the future? In which case an expansion on your answer of no might serve to enlighten many others.
  5. mapism
    Sardinia
    Well, I'm always a bit wary of dismissing something, because strong criticisms often spark divisive debates.
    And of course, personal experiences are... ermm... personal, so the YMMV principle is always valid.
    But since you asked, below is my 2c, in no particular order.
    With a premise: I'm only comparing IPS with shafts, not with outdrives - whose place is imho restricted to smallish speedboats.
    1) one inherent defect of fwd facing pods is that they are prone to grab even the smallest bit of line, which quite often damages the shaft seals, contaminating the oil with salt water.
    This means a liftup and props removal+seals replacement at best, and a whole pod replacement at worse. Either ways, $$$.
    In comparison, I can recall of at least 3 lines which I grabbed with my shaft powered boats.
    All of them ruined my day, but it only took a sharp knife and a tank of air to get rid of the problem.
    2) another inherent defect of pods (this time, regardless of their orientation) is that on planing hull they emphasize the listing upon steering at speed, because their vector thrust does not rotate along a vertical axis, but a diagonal one - as diagonal as the hull deadrise.
    As a consequence, builders are faced with the choice between two evils: either flatten the hull section astern, where pods must be installed (which in turn makes the boat more prone to slamming in head seas), or accept a rather scary behaviour while steering at speed (which is something that usually don't impress prospect clients upon sea trial - and rightly so).
    3) in terms of maintenance, on top of being already very expensive to do what VP recommends, sometimes it's not even enough. I'm aware of some cases where, in spite of having always strictly followed the echelon, the dreaded emulsionated oil or the notorious friction defect popped out of the blue, ruining the whole holiday of the boater involved.
    4) for any comparable installation (similar boat size/weight), the IPS fuel savings are nowhere near the 30% claimed by VP - not even remotely.
    5) the joystick is particularly attractive for inexperienced helmsmen, and there's nothing wrong with the principle of simplifying life to newcomers, of course. But as it happens, the very same joystick can become dangerous, in not sensible enough hands.
    I personally witnessed the case of a boat mooring stern to in between two other boats (and I appreciate that this is rare in the US, but it's the norm in the Med), where after reversing the boat reasonably well in its space, the helmsman used the throttle a bit too much to keep the boat from moving sideways.
    This made the boat, before even beginning to move sideways, to list so badly on one side that the walkaround rail of the boat collided with the other one on her side, in spite of the fact that both boats were well fendered along the hull.
    Thanks God, nobody on those boats were grabbing the rail with their hands in the fraction of second when that happened. Since one of the rails involved was bent (!), it's easy to guess what could have happened to any hands/fingers in between.
    And aside from this possibly extreme case, seeing IPS powered boats which suddenly list either side at the touch of the joystick, overbalancing the crew caught by surprise, is becoming typical enough to spot them (and their helmsmen ability :)) from some distance, when they approach a marina...
  6. NYCAP123
    People are allowed to have differences of opinion. That's how we learn, and why all cars aren't black (Henry Ford), as long as it isn't argumentative or involving politics. I think this is a safe topic. lol:) Let me give you my view.
    1) In theory you may be right, but in all these years I haven't heard of it being an issue any more than on any other boat. Quite frankly I can't remember ever pulling the prop on any of my outboards without finding fishing line wrapped, yet it's never cut the seal. Also on shaft boats getting line stuck on a prop is indeed a day spoiler. On outboards and I/O's it's usually involves nothing more than reversing it off. DK about IPS though as I've never had the issue.
    2) I've run a lot with IPS and I've never noticed any listing. You may have gotten that feeling because they track like rack and pinion steering. Turn the wheel and it reacts.
    3) Yes it's expensive. What in boating isn't? And of course they'll break down. When I step on any boat my constant thought is what's going to break next.
    4) And my Rav4 doesn't get the mileage Toyota advertised either. But a savings is a savings, and it does burn less.
    5) I'm sorry, but you're wrong on the handling. I've spun a lot of boats between the bows, and it's amazing to just twist a knob. Give me 1/2" over the length of my boat and IPS won't even raise my BP.
    One thing I should note, and a mistake some make is steering the boat by joystick while running. It's very sensitive and requires constant attention if you do that or else you get exactly what you described. It's easier and more relaxed to use the wheel. Save the joystick for close quarters.
  7. mapism
    Sardinia
    See? I did say that YMMV, didn't I? :)
    Btw, when you are talking of the IPS powered boats that you ran, they were not YOUR boats, I guess?
    I'm just assuming that yours is the timeless one in your avatar, which implies that you didn't choose IPS for yourself, no matter how well the ones you ran performed.
    It's a bit like Azimuts, really: they aren't loved by professionals, who wouldn't want one for themselves - and neither would I.
    BUT, they keep selling like hot cakes, and in their segment they are among the most popular boats in the planet, whether YF members like it or not.
    By the same token, I'm aware that IPS boats (some - certainly not all) can be nice to run.
    But I'm happy to leave them all available for anyone else interested in them.
    Just one comment about your reply, ref.5:
    I don't think I'm wrong, and not because I'm always right (don't we all think to be?! ;)), but because it ain't a matter of right or wrong.
    The problem is that the pods are powerful enough to push the boat sideways VERY rapidly (mind, I was NOT talking of twisting the knob to spin the boat on her own axis, but of lateral-only movements, by pushing the knob either to port or stbd).
    On top of that, the pods force vector (in contrast with traditional thrusters) is always diagonal rather than horizontal, whenever the computer rotates the pods in order to move the boat sideways.
    This means that there are two force components applied on the hull, whereas the vertical one is totally undesired but inevitable, and only translates in listing/rolling - in direct relationship with the total force applied.
    So, VP usually suggest boatbuilders to program the control unit for limiting the max power applicable upon maneuvering, no matter how hard the helmsman pushes the knob.
    If you tried some of these boats, you are unlikely to have noticed anything strange, but probably they couldn't move sideways as rapidly as theoretically possible.
    On the other hand, since the same result of smoothing sideways movements can also be achieved simply by being gentle with the knob, some other builders prefer to leave the choice to the helmsman, allowing more power to be applied upon translations, if and when the knob is pushed hard.
    Also because many newbies like that, since it reminds them of the behavior they are used to with their car, whose reactions are much more immediate than with any boat.
    Trouble is, upon the first moment of panic that sooner or later is bound to materialize, they tend to use the knob like there's no tomorrow - with the results I previously described.
    And which you might find hard to believe I suppose, but aside from telling you that I was there, and that the captain of the damaged boat asked me if I could give him my whereabouts as a witness for the insurance claim, I don't know what else I can say.
  8. NYCAP123
    Actually I wouldn't own a boat. Worked too hard for my money. No I transported them for dealerships, taught people how to run them and captained a few. One I brought from Detroit to eastern L.I.
    "The problem is that the pods are powerful enough to push the boat sideways VERY rapidly (mind, I was NOT talking of twisting the knob to spin the boat on her own axis, but of lateral-only movements, by pushing the knob either to port or stbd)."
    Absolutely that's the beauty of them, but it's also why you generally steer by the wheel not the joystick. The joystick is for close quarters maneuvering. To be honest I can't comment on vertical and horizontal forces. The drives are smarter than me. I just know how make them do what i want. What they're doing under the boat is for their brain to figure out.
    As for panic, I've had a lot more students panic trying to maneuver with gears and gas than simply pointing a joystick where they want to go, and if they did panic all they need do is drop the stick and it centers.
    Either that captain is in the wrong business or he had a brain malfunction (on the drive). It would be unusual, but I've had enough malfunctions on boats that I'd never say anything is impossible.
    As an independent captain I ran hundreds, if not thousands of boats in my career. Each one had a personality and I had about 30 seconds to figure it out. I'm not saying that everybody needs to drive IPS. I'm just saying they're pretty cool, give you more space, and bring more people into boating and with bigger boats cause it's easy to operate with it. Can't tell you how many boaters I've run into who bought a boat cause they're so cool, crashed it the first time they tried to dock and then never took it out again until someone gave them my number.
    P.S. I'm not familiar with YMMV?
  9. NYCAP123
    Btw the avatar is the boat I supervised the buy and refit of and captained the last several years before retiring after 30 years. See the thread Valhalla does the Loop.
  10. mapism
    Sardinia
    Haha, nope, actually the Capt I previously mentioned was already docked, and it's his boat that ended with a bent rail.
    The offending IPS-powered boat was maneuvered by her owner, and pretty sure he wasn't one of your students.
    Or a student of any experienced teacher, for that matter! o_O
    Ref vectorial forces, sorry if I got carried away by technicalities, anyway the effect I mentioned does NOT depend on whether the pods are controlled by the wheel or by the joystick.
    It depends on the fact that pods are installed on the bottom of V-shaped hulls, as opposed to commercial pods installed on tugs, ships, etc.
    That's in fact where pods began to be adopted, MANY years before VP had the brilliant idea of arm-twisting the concept also into planing hulls.
    Just think of outdrives, or rudders of shaft powered boats, or also commercial pods: all of them rotate along a vertical axis, as it should be.
    But with IPS, the rotation axis is instead diagonal - as much as the hull deadrise (deeper vee = more diagonal rotation), and there's no way round it.
    This is the anomaly that all IPS installations must deal with, and that requires several compromises.
    The joystick can emphasize the effect when handled too nervously upon close quarters maneuvering, of course. But also when hard steering at speed with the wheel, the higher listing (compared to any other propulsion) induced by diagonal thrust remains exactly the same.
    The extent of that depends on many factors, and there are boats where it's barely noticeable, but also others where it's downright scary.
    Sorry also for the YMMV acronym, it isn't nautical actually, more internet-driven in general.
    Just click here for a brief explanation. :)
  11. NYCAP123
    Absolutely the drives give lift and sharp reactions. That's the personality of the boat. Doesn't react like a jet ski but a lot faster than the Queen Mary. It's a sporty system.
  12. Capt J
    2. I agree with your statement on pods if mounted on the V, however when mounted straight, the pad for them is very small and I noticed no different in a head sea or slamming whatsoever. Most all builders, build the pods so they are straight, not on the same angle as the V.
    4. Look at the Cabo 40' for a direct comparison of 600HP Zues versus 800HP Mans. 80% LOAD- Zues 45 gph/33 knots, MAN 63 GPH, 32 knots.....it's 40%.
  13. Liam
    Liam Senior Member
    Malta
    Volvo IPS are not mounted in tunnels like the ZF Zeus one.
    You have to mount them on the bottom of the hull, with a V preferably less to a 15 degrees deadrise, going to a preferred 12 degrees number.
    Also Volvo does insist in making a flatter hull all along not only in the part where you have the pods.
    On the contrary the ZF Zeus aft looking pod does not have any hull shape constraints with the only exception being for making the tunnels to put the pods in them.
  14. ranger58sb
    Chesapeake Bay, USA
    Yes, it was a personal preference thing. The first showstopper was that the doorway into the master stateroom was too narrow; I had to turn slightly sideways to enter. The second was insufficient stand-up headroom on "my" side of the master berth. There were one-step-up raised platforms on either side of the master berth (leading to that headroom problem on one side), and I didn't care much for the step-ups, either.
    It was a nice boat overall, though.
    There would have been one engine/drive-related issue, if we pursued it further. That is, the only way to get near the inside portion of the pods is by slithering over the top of an engine... not a lot of space between engine and the underside of the cockpit sole above it. I'd have been willing to write an occasional check to some younger Volvo person to deal with that.
    It happens the whole cockpit sole was also removable, in case of catastrophic failure... and I thought that a very nice touch. Likely not something to do for minor maintenance, though.
    -Chris
  15. mapism
    Sardinia
    Far from being a SF expert, but your numbers strike me as evidence of a bad shaft hull, first and foremost.
    What happened at Cabo, did they forget how to build a decent boat on shafts?
    A quick search for Cabo 40 pointed me to a 2003 test published by SF Mag.
    According to it, back then the boat was capable of 42 mph top, and 35 mph (~30kts) @ 1800, burning 43 gph.
    A number that makes MUCH more sense than the 63 gph, and that corresponds to 1.4 G/Nm, instead of 2 G/Nm.
    That's a 30% savings with the older model (which btw was powered by the non-CR 700hp MANs, go figure!) vs. the boat you mentioned, both on shafts. Whiskey Tango Foxtrot?
    Now, even without knowing anything about the more modern version of the 40' that you mentioned, I can already tell that she doesn't have the same hull, because the 2003 model had a decent aft deadrise of 16.5 degrees, which is not IPS-compatible due to the inherent defect I previously mentioned, and that Liam specified further.
    So, my guess is that they redesigned the hull specifically for IPS installation, and then adapted shafts on it, rather than the other way round.
    Which make the numbers you quoted not exactly surprising, since they are due to a bad shafts hull - Q.E.D.
    All that aside, there is one general consideration that you should always bear in mind: any boatbuilder who decided to go down the IPS road will always praise the results achieved.
    Pretty sure you never saw an advertisement along the lines of...
    "We adopted IPS strictly because VP give us great discounts, to enlarge the number of installed packages, in order to make money with maintenance afterward. And on top of that, IPS also allows us to install the powerplant faster and with less skilled manpower.
    There are several drawbacks we are well aware of, obviously. The most noticeable one being the fact that we will have to trade seaworthiness for the IPS installation requirements.
    But let's not forget the IPS advantages for you, like the joystick for those who don't have a clue about how a boat should be handled, and the larger interiors because we can squeeze the e/room to the point that mechanics will go nuts, eventually costing you even more.
    But hey, boats are just toys for rich boys anyway, aren't they?"
    Now, do you know why you never saw anything like that?
    Because it would be true, that's why. :D
    Fiammetta42 likes this.
  16. mapism
    Sardinia
    Hang on, I just noticed that your comparison was between a shaft and a Zeus (not an IPS) boat, and that does make a difference.
    My previous post was obviously focused on IPS, which is what we discussed so far.
    The comparison between the 2003 Cabo 40' and the one you mentioned remains equally hard to justify, anyhow.
    63 gph is more of what my 800hp MANs burn on a 56 footer that weighs more than twice the Cabo 40...?!?
  17. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    Some interesting data while surfing the net for a Zeus power 40 Cabo Express, about 32 knots at 46 gph.
    https://dicksimonyachts.com/Brochures/Cabo/Archives/Cabo-40-Express-Motorboating-Jan-2009.pdf
    Then a bounty of Cabo sea trial data with a 40 Express , about 32 knots at 51 gph with C12’s, about 32 knots at 63 gph with 800 MAN’s.
    https://media.channelblade.com/EProWebsiteMedia/2964/Std_Sea_Trial_C32X-08_CAT_C7.xls.pdf
    No surprise the Zeus marketing guys use the 63 gph to fit their narrative, when 51 - 46 = 5 gph, about a 10% efficiency improvement, more like it if you are targeting efficiency on both sides of the equation.
  18. Capt J
    I NEVER saw a 32 knot cruise with the C12's in a 40' express with only a hardtop (no riggers, no tower) only saw 30.2 knots. They were also very noisy in the helm area and Cabo built few C12 boats compared to MAN or Zues boats......most were MAN boats.
    CMD was comparing apples to apples when everyone wanted speed...…..32 knots with 800 MAN's at 63 gph…...33 knots at 45 GPH with the Zues (both nearly identical towered, expresses). Also the boat handled better with the ZUES' lighter weight, less noise at the helm, and tight turning radius.
  19. PacBlue
    Dana Point, Ca
    The comparison is off of published data , even from the manufacturer, so you have to go with the known data. It would only be an apples to apples comparison if they ran a Zeus and Shaft version of the QSC8,3 or the 800 Man, that is really the only way to determine efficiency on an apples to apples basis. Otherwise it is a marketing example.
    At 46 gph the Zeus is 27% more efficient in fuel burn, but it is not a true apples to apples comparison.
    Not questioning any of the merits of Zeus, I ran and tested the first prototypes at Sea Ray in Merritt Island and the Mercury facility in Oshkosh, Wisconsin, I am well aware of their benefits and their challenges. At one time we were going to have a Sea Ray 44 Sundance built with Zeus and IPS for a head to head comparison but VP backed out of the deal at the last minute. That would have been an interesting comparison.
    My notes show a 44 SR Sundancer with 500hp QSC Cummins conventional shafts burned 37 gph at 30 mph cruise, while the 425 hp QSB Zeus used 32 gph at 30 mph and the 480hp QSB Zeus used 30 gph at the same 30 mph. At (37 - 30)/37 = 19% real world efficiency. The Zeus boats where better all around and had significantly higher top speeds and a greater bandwidth of useable cruise speed, no doubt the better package. All done in 2007.
  20. NYCAP123
    Now that Zeus has been shelved what kind of support is available for them or do those boats now have to be retrofitted with conventional drives?
