Click for Ocean Alexander Click for YF Listing Service Click for Burger Click for Westport Click for Abeking
Rock the boat...
Discussion in 'General Yachting Discussion' started by YachtForums, May 6, 2014.
  1. ScotL
    ScotL Senior Member
    Green Bay/Milwaukee,WI
    I am not sure it is related to the server, but this is the issue I am having (if I log out, I can see the images though):
  2. Old Phart
    Old Phart Senior Member
    I dunno
    It took pity on me, finally. :D
  3. YachtForums
    Scot,
    Can you check your UserCP on JF to see if "Show Images" is checked in "Thread Display Options"?
    Go to UserCP on the NavBar > Settings & Options > Edit Options > Thread Display Options.
    I'll double check the global settings when I get back to the office.
  4. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    I've just gone into JF straight from my Favourites Bar, didn't even need to log in.
    I am running Adblocker, would that change things?
  5. ScotL
    ScotL Senior Member
    The box is checked. Here is another screensshot of what I get when I click on the image link:
      36.9 KB
  6. Kevin
    Just checked everything on my end Carl and it's working. Logged out, logged in, posted, checked images... everything a-ok.
  7. YachtForums
    Scot,
    Are you on IE8 by chance?
  8. ScotL
    ScotL Senior Member
    Chrome. I prefer to NOT use IE at all. Do you want me to try IE or FF?
  9. YachtForums
    Yes please.
  10. YachtForums
    OK, found the problem. You were in "Users Awaiting Email Confirmation" status. I just manually registered your account. When you originally signed-up, you should have received an automated mailer that requires you to follow a link that let's us know you're a human, not a bot. Now that we know you're a carbon based life form, you should be good!
  11. YachtForums
    Thanks to everyone for their help!
  12. ScotL
    ScotL Senior Member
    I am getting this error in IE to start and then having the same problem with not being logged in as Old Phart did.
    "Could not find phrase 'invalid_redirect_url_x'."
    Everything seems to work in FF. I was geting the same error as above but when I hit the home button, it showed me as logged in.
  13. ScotL
    ScotL Senior Member
    Thanks Carl. I was sure I had done that as I have been to the forum many times.
  14. YachtForums
    Don't blame your memory, it may have been my fault. I can't recall if email verification was enabled at the time. When I originally introduced JetForums in a mailer to YF members, I removed all the normal registration hurdles because everyone signing up was a member of YF, therefore they've been previously screened.
  15. Fishtigua
    Guernsey/Antigua
    Screened???:eek:
    How the heck are most us still here? :D
  16. Kevin
    Loose standards...
  17. Berean
    Berean Senior Member
    Sarasota FL
    I'll say...
