Click for Mag Bay Click for Furuno Click for Delta Click for Mulder Click for Walker
Replacing smaller stern hawse pipes for larger?
Discussion in 'Ocean Yacht' started by Matt Clark, Dec 31, 2020.
  1. Matt Clark
    Matt Clark Member
    Sylvan Lake, MI
    I have a 1990 44' that I would like to have my stern hawe pipes replaced for larger ones as I want to be able to get my shorepower through them. Has anyone done that? I ran it by my marina fiberglass guy and he is trying to do some research but just checking to give him info if any of you have done this. Thanks
    You'd of course want to do it on both sides to keep it symmetrical. Sounds like a lot of work and expense to cure a minor inconvenience and you could end up with a bigger inconvenience if you cruise a lot (feeding the cord through each time, especially when cold and stiff) . There's probably a lot simpler solutions to your situation, maybe involving Velcro straps.
  3. Jdow
    Jdow New Member
    Massachusetts
    We did this on a refit a couple years ago when I upgraded a 65 Viking to 100 amp service. It was quite expensive to get custom hawse pipes made at the yard, but worked out very well. If you want I can measure the old ones I still have in storage next week and see if they will work for what your trying to do.
  4. Matt Clark
    Matt Clark Member
    Sylvan Lake, MI
    That would be great. Please let me know. In the meantime I will talk to my glass guy to see if he has come up wiht anything yet.
  5. chesapeake46
    chesapeake46 Senior Member
  6. Jdow
    Jdow New Member
    Massachusetts
    Checked them today, a 50 amp cord cap does not fit through them unfortunately
  7. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Did you think of installing a Glendenning cord reel ? Put your exit on the transom. I don't know if that boat has space , that's to be investigated. But I suspect when you calculate the Howse cost this won't be that painful and a lot more convenient than lugging a 50amp cord around.
  8. Matt Clark
    Matt Clark Member
    Sylvan Lake, MI
    Thanks for checking
  9. Matt Clark
    Matt Clark Member
    Sylvan Lake, MI
    I have a Glendenning already installed that came with the boat but the exit comes out at the base of the lazarett so no changing that. Thanks for the suggestion
  10. Matt Clark
    Matt Clark Member
    Sylvan Lake, MI
  11. BigChief
    BigChief Member
    CT
    The hause pipes on my 48 allow the glendening 50 amp to go thru no problem.
    Can you source 2 of those?
  12. Matt Clark
    Matt Clark Member
    Sylvan Lake, MI
    Thanks. I have my fiberglass guy looking in to it. Which of the three models sizes on that link do you have?
