Click for Westport Click for YF Listing Service Click for Walker Click for Ocean Alexander Click for Delta
Replacing Flooded Battery With AGM
Discussion in 'Luhrs Yacht' started by Hot Rod, Dec 21, 2009.
  1. Capt J
    then why not use the same battery type for both the house and starting? It just sounds like the whole system is getting over-complicated.......or mount another alternator on one engine that only charges the house? Cabo uses a system where one motor will charge all of the batteries.........but they use the same type of battery for everything............ or just let the house batteries charge from the generator and have a battery switch where you can combine both one engine and the house in an emergency situation........why not leave the generator running while fishing? Everyone I know, never shuts the generator off.......
  2. Hot Rod
    Hot Rod New Member
    Blue Water Point Marina, Oak Island, NC
    Capt J, you raise some very valuable and logical issues with my approach. I hope you will find my answers equally as logical for my particular needs. I will take each observation one at a time. Thanks for helping.
    "then why not use the same battery type for both the house and starting?"
    I must admit, I am still struggling with this one. The primary reason is cost. The Deka SM8A8DM AGM battery is $488 while the Deka (NAPA 7271) Wet battery is $183. The second reason is functionality. The Wet is better at cranking and the AGM is better at cycling. If I were going to use only one battery type, I would have to go to all AGMs, as the Wet will fail in a short time period if cycled. I already have both battery chargers. The ProMariner ProTech-4 (the one that came on the boat) does not have a separate charging cycle for AGMs, so if I used it, I would be mixing charging profiles. If I don't use it I am losing 50 AMPs of charging power. The new smart ProMariner ProNautic has 2 AGM charging profiles to choose from.
    If charged & maintained properly, the life expectancies of 2 8D AGM batteries and 2 HD Wet/Flooded batteries are close. The 2 AGMs are $600 more. . . . . I am still struggling with this one.
    "or mount another alternator on one engine that only charges the house?"
    That is a good suggestion and I will think more about it in detail. I had initially run from the amount of work involved in setting up the mounting hardware and pulley configuration to run a second alternator. I have built a few cars in my lifetime (www.BullockCars.com), so I will rethink it again.
    "or just let the house batteries charge from the generator and have a battery switch where you can combine both one engine and the house in an emergency situation........"
    This is my current plan, now that I have discovered that my Hitachi alternators will not work with a battery isolator. I have a Kohler 8-32EOZD generator that provides AC power for the battery chargers. I think the switched solenoid, to combine the crank and house batteries makes since.
    "why not leave the generator running while fishing?"
    When I fish overnight, I have not turned it off, nor will I. When I fish for an afternoon and anchor up, it is nice to not smell the diesel and to be able to hear the ocean sounds. On one of these afternoon fishing excursions, a dead cranking battery is what led me to discover how the 36 Luhrs' batteries are wired. My redesign is to allow me to fish and still be able to crank and come home on time.
    I would love to read more of your thoughts and ideas. Thank you!
  3. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
    Battery Charging Specifics
    Hot Rod-
    I started studying this subject about a year ago because I was perplexed in the number of premature lead acid (LA) (flooded lead acid (FLA), gelled electrolyte (GEL) or absorbed glass mat (AGM)) battery failures that I was seeing in my business. I have come to several conclusions:
    1. We are chronically undercharging out batteries because of insufficient time spent in the absorption stage of the standard three stage charging algorithm.
    2. Sulphation and premature failure of the batteries is a direct result of #1 above.
    3. Many battery charging source (alternator, alternator regulator, inverter/chargers and charger) manufacturers are trying to build products with charging profiles that attempt to hit an industry average regarding bulk to absorption transition voltage and time in absorption stage. These average values are just plain wrong for many different batteries.
    4. The transition from absorption to float is oftentimes a simple timer circuit and even when there are other criteria (charging current <2% of declared capacity (C) being the most prevalent), other factors may come into play that prematurely stop the absorption stage.
    5. As with the absorption voltage in #3 above, the float voltages in the profiles are oft times too conservative (low).
    6. All LA batteries will suffer from stratification and sulphation if left on float for extended periods with no exercise.
    7. All LA batteries, should be charged with a temperature compensated charging source to ensure the maximum cycle life from the batteries. This temperature compensation is usually in the range of -20 to -30 mVDC/degree C for temperatures in excess of 25C (77F). For temperatures < 25C, the temperature compensation is positive.
    8. Heat is the biggest killer of batteries. There are two sources of heat that will damage LA batteries; heat generated during the charging process and ambient, or environmental, heat.
    9. The heat generated during the charging process can be mitigated by:
    - limiting the charging current during the bulk stage to the manufacturers' specifications. A well known battery manufacturer has reduced the bulk charge specification from .25C to .17C over the last couple of years.
    - allowing space between the batteries mounted in a bank.
    - consider forced ventilation for the battery bank.
    - consider the effects of the environmental heat and the additive nature to the heat generated during the charging process.
    10. Environmental heat. LA batteries in engine rooms are going to suffer premature failure due to the high ambient temperatures they are exposed to. For every 10 degrees C (18 degrees F) above 25 degrees C (77 degrees F), battery cycle life can be reduced by as much as 50%.
    There is more, but you get the drift. You might ask, "Why does this matter now and why didn't it matter years ago?" When LA batteries were considered a consumable and we could buy an FLA 8D for $125, it was just a fact of life that we struggled with strained backs to change them out every two or three years. Today, Defender's 8D (SKU 201050) is $271. The more exotic GELs and AGMs are more costly to produce and an AGM 8D (Defender SKU 204206) costs $881. So, replacement cost has become the motivator for ensuring the longest possible cycle life of batteries.
    So here is my advice:
    Match the battery charging sources characteristics to the battery manufacturers' specifications; do not violate the 50% depth of discharge rule; use temperature compensated charging sources; exercise the batteries regularly; ensure that the batteries are fully charged (long enough absorption time); and finally, keep the batteries as cool as possible.
  4. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
    Hot Rod-
    A things to think about regarding your system:
    1. Use a battery combiner; e.g., Blue Sea Systems 7600 in lieu of the battery isolator. No voltage drop.
    2. For mixed battery chemistry, use a Balmar DuoCharge to charge the FLA starting bank. Max. capacity is 30A and they can be adjusted for battery chemistry. Since starting a diesel takes <5 amp-hrs, replenishing the starting bank is PDQ.
    Due to the cost of the AGM for the house batteries, I would just go with deep cycle lead/acid on the house batteries. You could replace them more then once for the price of the AGM's which may last an extra year........It would simplify things. I think the AGM's are over-rated, and as engine starting batteries I have never seen them last longer then their lead acid counterparts. House batteries I did see them last over 5 years on one yacht, but this yacht had 18 8D's for a 65' Yacht. You'd be surprised how many times you can cycle a lead acid, as long as it has light stable loads and you're not hitting it with a diesel's starter when it's down.......Look at how many thousands of bass boats have lead acid batteries for their trolling motors that they run down all day and then charge at night.......
  6. Hot Rod
    Hot Rod New Member
    Charlie J
    Fascinating read! Thanks for taking the time.
    The location currently planned for my 2 8D House batteries is under a port bench seat on the bridge. Your # 9 & 10 points above, caused me to think about using a voltage sensitive relay to power a muffin fan to ventillate the contained space under the cushion. It would only work when the batteries were being charged and should dissapate the heat. So, thanks for that!
    Carl
  7. Hot Rod
    Hot Rod New Member
    Thanks for all of your inputs thus far. I have reached some preliminary direction with the charging system, but I need more help.
    I plan on connecting the port alternator directly to the port cranking battery and using a Voltage Sensitive Relay to connect it with the starboard cranking battery. These Yanmar diesels are electronically controlled and I was told today by the factory that they use between 25-30 amps to run. Now that I have had time to study a lot of variables, I can see some major disadvantages to running the port alternator through a battery isolator. What are your opinions?
    I am still up in the air about how to connect the starboard alternator. I do have a large load draw on the house/electronic battery bank and a 2 hour run to the fishing grounds. I sure would not want to start with drained batteries. Connecting the port alternator directly to the house/electronics battery bank will replace the amps being used, but I am not sure if the charging rate will be too high for the AGMs. What do you think about sending that charge through one half of a high output battery isolator and dead ending the other half? Would the diode reduce amperage transferred? I know it will charge at, let's say a .7 volts lower rate, but will the amperage be less? I am attaching my alternator specifications page for the electronics experts out there to analyze.
    My backup for the alternators is the on board Kohler 8-32EOZD generator. The generator will power a ProMariner proTech-4 1250 battery charger (50 amp) for the 2 8D wet cranking batteries and a ProMariner ProNautic 1260 C3 (60 amp) battery charger for the 2 8D AGM house/electronics batteries. I do run my generator when I am running the main engines.
    Need help with this charging phase. Help by getting all of the different options out there, along with the Pros & Cons.
    Thanks,
    Carl
  8. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
    I think that battery isolators had their place but that place has been taken over by battery combiners; a.k.a., Automatic Charge Relays (Blue Sea) or Voltage Sensitive Relays (BEP).
    AGMs can be charged to their capacity or higher. Charging current is not the problem; higher voltage than the battery manufacturer's spec is.
    No, using a battery isolator will reduce the voltage and you will chronically undercharge the AGMs.
    When running multiple charging sources simultaneously one of the sources is going to predominate the others and you won't know until you do a trial and error. My guess is that the Pronautic with its sophisticated charging algorithm will dominate the internally regulated alternator on the house side and the ProTech will dominate the port alternator on the starting bank.
  9. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Why not just use the alternators (with a small buffer battery) to run an inverter which powers the battery chargers?
    Although I don't think you will have any problems just hooking the alternators to the batteries.
  10. Hot Rod
    Hot Rod New Member
    I am almost to that conclusion too, just need to understand the charge voltage needs of an AGM better. My ProNautic battery charger manual indicates that it charges an AGM to 14.3 volts during the absorption phase, while charging a Flooded to 14.8 volts. Since the diode of the isolator reduces the charging voltage by .7 volts, wouldn't that more close approximate the requirements of the AGM battery type? My alternator's regulated voltage is 14.5 volts and its output current for 13.5 volts is 75 amps (from the previously posted schematic).
    This is the remaining part of the charging algorithm that is not clear to me. If the 14.5 volts is reduced to 13.8 volts through the diode, would it provide the stated 75 amps reflected in the schematic, or would the diode reduce the amperage too?
    My only fear is that my alternators will charge the AGMs to a voltage that is higher than recommended and it appears from my battery charging manual that the AGM voltage is .5 volts lower than the Flooded. Since my Hitachi alternators were setup from Yanmar to charge Flooded batteries, wouldn't it be better to reduce the regulated rate by .5 volt? Since I can't very easily do this because my regulators are internally regulated, would the diode do this? I would appreciate any and all help with confusion.
    You may be right, but like you said, we probably won't know until we do a trial and error. I did ask that question of Ian, a technician from ProMarina, and here is a copy of his email.
    To: carl@xxxxxxxx.com
    Sent: 12/15/2009 9:26:39 A.M. Eastern Standard Time
    Subj: RE: Professional Mariner
    Hi Carl
    If the charger and alt are running at the same time.
    The alt will over power the charger.
    So the charger powers back.
    Because the alt has a higher amperage output.
    Give me a call will talk shop.
    My direct line is 603-xxx-xxxx.
    Ian
  11. Hot Rod
    Hot Rod New Member
    I never thought about that. Henning, that is very creative! Thank you.:)
    Do you know what the approximate losses would be going through that process?
    Thanks,
    Carl
  12. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
    If the inverter is 85% efficient and the charger is 90% efficient then your efficiency from alternator to battery is .85 x .90 = 77%. And you have certainly added some more complexity.
    Charlie
  13. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
    What are the battery specs for the AGMs you are installing on your boat? As I tried to point out in my long post above, these number are not consistant across all battery manufacturers and the AGM1 setting may not be appropriate for your batteries.
  14. Hot Rod
    Hot Rod New Member
    This information is for Deka AGM batteries and came from their web site.
    DEKA AGM Battery Charge Voltage​
    Temp F --- Optimum Charge --- Maximum Charge
    > 120 ----------- 13.6 ----------------- 13.9
    110-120 --------- 13.8 ----------------- 14.1
    100-110 --------- 13.9 ----------------- 14.2
    90-100 ---------- 14.0 ----------------- 14.3
    80-90 ------------14.1 ----------------- 14.4
    70-80 ----------- 14.3 ----------------- 14.6
    60-70 ----------- 14.45 ---------------- 14.75
    50-60 ----------- 14.6 ----------------- 14.9
    40-50 ----------- 14.8 ----------------- 15.1
    <50 ------------- 15.1 ----------------- 15.4
    Details
    How critical is recharge voltage?
    Why are all VRLA batteries so charge
    sensitive?
    All lead-acid batteries give off hydrogen from the negative plate
    and oxygen from the positive plate during charging.
    VRLA batteries have pressure-sensitive valves. Without the ability
    to retain pressure within the cells, hydrogen and oxygen would be
    lost to the atmosphere, eventually drying out the electrolyte and
    separators.
    Voltage is electrical pressure. Charge (ampere-hours) is a quantity
    of electricity. Current (amperes) is electrical flow (charging speed).
    A battery can only store a certain quantity of electricity. The closer
    it gets to being fully charged, the slower it must be charged.
    Temperature also affects charging.
    If the right pressure (voltage) is used for the temperature, a battery
    will accept charge at its ideal rate. If too much pressure is used,
    charge will be forced through the battery faster than it can be
    stored. Reactions other than the charging reaction occur to
    transport this current through the battery—mainly gassing.
    Hydrogen and oxygen are given off faster than the recombination
    reaction. This raises the pressure until the pressure relief valve
    opens. The gas lost cannot be replaced. Any VRLA battery will dry
    out and fail prematurely if it experiences excessive overcharge.
    Note: It is the pressure (voltage) that initiates this problem—
    a battery can be “over-charged” (damaged by too much voltage)
    even though it is not fully “charged.”
    This is why charging voltage must be carefully regulated and
    temperature compensated to the values on the chart above.
  15. wingless
    wingless Member
    East Coast
    The temperature compensation on fast-rate chargers is enhanced by remote thermocouples to measure the battery temperature.
    A battery self-heats during charging and discharging, so a charger monitoring ambient temperature might not detect the elevated temperature from self-heating and overcharge / damage the battery.
  16. Hot Rod
    Hot Rod New Member
    Battery Isolators May Be The Answer For Charging AGMs With Alternators
    I have pasted below an email with answers to some battery isolator questions that should be of interest to all of us boaters with alternator charging questions. These answers are very revealing about the unique qualities of battery isolators and how they may be the optimum solution to charging AGM type batteries with alternators (when external regulators are not an option). This email came from an engineer that was involved with the development of fiber optics in the telecommunications industry. I have feedback from equally qualified sources (just received in the last 2 days) and all have provided similar responses. This email was graciously written for ease of understanding, so I have posted it as it was written.
    "First the long answer. Then below that the short answer to Carl Bullock's questions with my comments added in Red.
    These are silicon diodes being discussed if they are said to have 0.7 volts drop. Current flows thru them in only one direction. They will have a voltage drop across them of a nominal ).7 volts dc. That drop will vary slightly from almost no current up to the maximum rating of the diode. The actual drop will depend a little bit on the amount of current and on the temperature, But in general it will be less than plus or minus ).05 volt, i.e. 0.65 to 0.75 over the extreme worst cases.
    So yes, putting a diode between the charger and the battery will reduce the maximum voltage that the battery gets charged up to with that particular charger. However when ever the battery voltage is less than that maximum, the battery will soak up the same amount of charge current as the charger would normally supply.
    Chargers are set up to work in the current limited mode when the battery voltage is low. The current limit is set small for trickle chargers. So the charger can be smaller and cheaper. Also it will not cause much temperature rise of the battery and therefore not boil out any water. High power chargers will have the maximum charging current set to a limit that does not overheat/overload the charger. That will charge the battery faster but also cause the battery to get hotter.
    During the charge cycle as the battery voltage builds up, the charge current will eventually drop off as the battery approaches its fully charged voltage level. The final charged voltage will be 0.7 volts less if a diode it used.
    My guess is that if the charger voltage was correct in the first place for the particular battery type, then yes putting a diode in the circuit will cause charging to stop a little sooner. However in terms of the total amount of charge put into the battery, that it will probably be only a few percent less than if no diode was used. The difference is probably no greater than the amount of charge a battery can hold when it is charged on a summer day versus a winter day. So the whole argument is probably about a small percentage of charge difference and also about only a small difference in time to do a full charge."
    On Jan 11, 2010, at 6:55 AM, xxxxxxx@xxx.com wrote:
    "Questions from Carl Bullock:
    A battery isolator reduces the charging voltage by .7 volts and because of this, some say that it undercharges batteries. I am thinking about purchasing AGM batteries for my boat, that will be damaged if charged at too high of voltage. The battery manufacturer is suggesting that the maximum AGM charge voltage should be .5 volts lower than for their Flooded (Wet) batteries.
    I immediately thought that a battery isolator would be the solution, since my alternator is internally regulated and not easily changed. Some on those posting on the boat forums came back and said that isolators undercharge batteries. I would agree, if one was charging Wet batteries.
    This has led me to try and understand how current is passed though the heavy duty split charge diode. From the literature that I have read, it sounds that once the "electrons and holes are pushed towards the junction, the distance between them decreases. This lowers the barrier in potential. With increasing forward-bias voltage, the depletion zone eventually becomes thin enough that the zone's electric field can't counteract charge carrier motion across the p–n junction, consequently reducing electrical resistance".
    From this, I am getting the impression that the diode junction results in a .7 volt lower passing voltage, but the current flow will be barely change. CORRECT
    So my question is; Will my alternator transfer close to the same 75 amps (maximum alternator output, assuming a drained batter) going through the battery isolator at a reduced charging voltage of 13.8 volts as it does going directly to the battery, without using an isolator and charging at a rate of 14.5 volts? YES
    In other words, does a battery isolator reduce the amperage in the same way that it reduces the charging voltage rate by .7 volts? NO
    I am trying to compensate for the .5 volt lower charging needs of the AGM battery type by using a battery isolator. I don't want to over heat the batteries during the charging process but I want to charge them as fast as practical. I will be able to finish off any incomplete charges with an AGM specific on board AC battery charger after the main engine's alternators have been shut down. The small amount of additional charge obtained may not be worth the effort.
    Thanks in advance for your help,
    Carl Bullock"
  17. Hot Rod
    Hot Rod New Member
    I am creating a stand alone House/Electronics battery bank. I am thinking about using a 150 Amp Blue Sea 185-Series circuit breaker for my house/electronics battery bank cable thermal protection. From what I have read (Interrupt Rating of 3,000 Amperes), I am also thinking that this circuit breaker will meet the American Boat and Yacht Council (ABYC) requirements for battery switches. If this is the case, I can eliminate the purchase/installation of an additional On/OFF battery switch for this bank.
    Would like to hear others' opinions on this.
    http://bluesea.com/category/3/10/pro...ne/overview/13
    185-Series Thermal Circuit Breaker Panel Mount
    Product Overview Detailed Specifications
    •Ignition protected - Safe for installation aboard gasoline powered boats
    •Meets SAE J1171 external ignition protection requirements
    •Weather Resistant
    •Combines switching and circuit breaker function into one unit
    •"Trip Free" - cannot be held closed after trip
    SpecificationsInterrupt Rating 3,000 Amperes
    Maximum Voltage Rating 42 Volts DC
    Operating Temperature Range -25°C to +82°C
    Circuit Breaker Type Thermally responsive bi-metal blade
    Circuit Breaker Class Type III - Switchable/Manual Reset - Trip Free
    Terminal Stud Size 1/4"-28
    Terminal Stud Torque 50 in-lb
    Mounting Holes Accept 1/4" (M6) Screw
    Weight Lb (Kg) 0.25 (0.11)
    Case Material Phenolic
  18. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
    To be in compliance with ABYC E-11 you have to match the AIC of the breaker with the potential energy in the battery that it may have to interrupt in a dead short condition and still be operable. The first breaker downstream from the battery is the main breaker; all breakers downstream from the main breaker are branch breakers.
    From Table IVA in E-11; 12 and 24 volt systems:
    CCA < 650; Main AIC 1500 amp; Branch AIC 750 amp
    CCA 651 to 1100; Main AIC 3000 amp; Branch AIC 1500 amp
    CCA > 1100; Main AIC 5000 amp; Branch AIC 2500 amp
    Hope this helps.
  19. Hot Rod
    Hot Rod New Member
    Charlie, thanks for the reply and helpful information.
    My battery bank is comprised of 2 8D Deka AGM batteries with 1450 CCA each, making a total of 2900 CCA. The Table IVA in E-11 reflects a need for 5,000 AMPs. I assume that table is referring to Ampere Interrupt Capacity.
    Since the Blue Sea 185-Series thermal circuit breaker only has an Interrupt Rating of 3,000 Amperes, It will not work. It appears that I will need to use a fuse like the Blue Sea ANL series which has 6,000 Ampere Interrupt Capacity (AIC) and Blue Sea states that it satisfies ABYC requirements for main DC circuit protection on large battery banks.
    That would also mean that I would need to install a stand alone ABYC compliant On/Off switch rated at over 5,000 amp interrupt capacity.
    Would you agree?
    I have not been able to find a thermal circuit breaker (panel mount) rated at 150 AMPs that has higher than the 3,000 AMP interrupt capacity. Do you know of any that meet the 5,000 AMP ABYC requirement?
    http://bluesea.com/category/5/22/productline/overview/135
  20. CharlieJ
    CharlieJ New Member
    St. Petersburg, FL
