Click for Abeking Click for CL Yachts 99X Click for Delta Click for Abeking Click for Nordhavn
Raritan Icer-Ette
Discussion in 'Carver Yacht' started by Monepit, Jul 29, 2014.
  1. Aimhii
    Aimhii Member
    Port Severn
    Hey, I will try anything and everything before I have to start shelling out $$$
    If I give up, then I will have no choice but to throw $$ at the problem.
    Stay Thirsty my Friends….lol
    For the small amount of freon the unit takes, why not just evacuate it and recharge it? Sometimes it's better to pay $150 to fix something, than $1500 to replace it because the fixable one was destroyed!
  3. Aimhii
    Aimhii Member
    Port Severn
    Because there is no AC Man in the area and he charges $120/hr. So 2hrs just for the trip here and back and who knows how long to play with it and what else he needs? Freon, parts, etc…..Better off trying myself or biting the bullet and replace or go without. The AC man drives an exotic car and big boat here from where he works…I assume he didn't get it by getting lucky?
    In my case I got lucky and fixed my self without evacuating, because if I didn't do it right I would of damaged the coils and then would of had to replace the whole **** thing anyways.
    Hope that helps the picture come in clearer?
    It sounds like your unit is low on Freon and not getting cold enough to make and keep ice and there is nothing wrong with the mold assembly. The unit I have and others I have seen, literally will go from turned off 90F to ice in the bin in 20-30 minutes. In 5-10 minutes the entire freezer will be super cold. Put a pint of ice cream in the empty ice bin and see how hard it stays or gets.....or test it with a thermometer.....
  5. Monepit
    Monepit Member
    Evansville, in
    I'm sure mine is freezing. I've been buying ic at the marina and keeping it in the icemaker for 2 years now. I figure it worth $160 to try to fix it. I also hate to pt 4 or 5 hundred in it to have it fixed since the unit is 15 years old.
  6. gbarger
    gbarger New Member
    arkansas
    Hey, report back on how it goes. Mine is working great, but I know sometime in future, it would be nice to replace the whole mold assembly.
    thanks
  7. Monepit
    Monepit Member
    Evansville, in
    We have ice. I replaced the icemaker assembly using the procedure Aimhii recommended here. Thank you. I also had one tech at raratan that said that would work. The other said no way. I figured for $160 it was worth a try. It took about a half hour and started producing in in about 20 minutes for the first time in years. Had a full bin the next morning. Emptied it and another full bin that night. Isn't it am aging what you can learn on the internet. Thank you Aimhii and yacht forums for the help.
  8. Aimhii
    Aimhii Member
    Port Severn
    Hey - that's what this forum is all about!
    Just an update as well.... I caulked the inside gaps in the ice maker and turned on for an hour with arm up so as no water was pumped in and let box get cold.
    Put down arm later and nice dry cubes... No more blocks!
    Take that you AC heat/Air dudes....lol
  9. jimmelbaking
    jimmelbaking New Member
    Kemah
    The plastic water tube came loose, and for the life of me I can not find where it attaches to the ice tray. The plastic out of the water valve got brittle and broke and when cutting off the end and inserting the other end came loose and I can not find where it goes. Help. Thanks
  10. BIlljhs
    BIlljhs New Member
    Toms River
    I know this is an old thread but how does the compressor stay on if you have to pull the wiring harness of the mold tray to replace it????
    BIll
  11. Capt Ralph
    Compressor needs to be off.
    Most Icer-etts's must have the freon pumped out also.
    It looks like a U-Line but not serviced like one.
    The cold plate will expand like a balloon if the ice maker is removed while charged, running or not.
  12. BIlljhs
    BIlljhs New Member
    Toms River
    Good afternoon Capt. Ralph....I did read that in the beginning of the thread but I saw where a few guys said they did it by keeping the unit on when replacing the tray...my problem is finding someone to do the evacuation and recharge of such an old system....
  13. Capt Ralph
    Keeping it on? The ice maker controls the compressor.
    Now I understand your original post.
    Any A/C guy with R410 and a scale can do it.
    It requires the scale because of the exact amount of R410 to be injected back in.
    Is the boat (or ice maker) up north or down here?
  14. BIlljhs
    BIlljhs New Member
    Toms River
    We are up in NJ.....according to the Raritan company it has R12 in it....not too common....unit was built in 2003 and I am having a time trying to find someone who will touch it.....
    That's the reason I was wondering how the guys in the early part of the thread were doing it with the power on...I thought the same thing...the compressor would be off if you pull the tray out....but maybe the compressor doesn't care about the timer control on the actual tray.....got me
  15. Capt Ralph
    Naw, the off/on timers are in the ice maker. I guess they jumped the 3rd pin on the thermostat.
    R12? Not sure about that.
    I still have real R12 (gold gas) in my inventory that I use on real old stuff, WAY before 2003.
    Ship it to Raritan or ship it to me if your not sure about this stuff.
