Click for Northern Lights Click for Nordhavn Click for Burger Click for Ocean Alexander Click for CL Yachts 99X
Quick Lift Davit.
Discussion in 'Technical Discussion' started by Captain Estee, Mar 2, 2022.
  1. Captain Estee
    Captain Estee New Member
    Claremont, CA
    There is a rubber plug at the top is where you fill hydraulic fluid and vents as well. The prior owner used a Biodegradable hydraulic fluid in mine made by green marine so I stuck with that. But I'm sure any hydraulic fluid would work. I also found on the lift to spray a lubricant on the solenoids if they start sticking. You can manually move the pistons as well.
  2. geologydave
    geologydave New Member
    Cape Coral,FL
    Looking for a ten pin male barrel exterior 12v electrical connector. strange pin arrangement. For a Quick lift 1600 that has delivered outstanding service for almost two decades now.
    Any info on how to contact them or where I can find this will be greatly appreciated.[​IMG]
    Dave
  3. Pascal
    It a probably just a basic industrial connector. Is it for the remote ?
    try calling Danny at Chock Master’s. He used to run Quick Lift with his brother
    https://tenderchocks.com/
  4. geologydave
    Cape Coral,FL
    Yes it is for the remote, it seems basic and cheap there are millions of 10 pin connectors out there but that configuration seems rare, I can't find one after a bunch of looking, this post was a last resort. I used your info here to call Danny(prior to your response); but he said that they have zero of anything- support, parts, nada. Quick Lift is completely and totally gone. That is a bummer, damn good davit, I've had a few and this is the best by far.
    Thanks for your response.
    UMT marine makes a similar looking davit, sent them a pic, maybe I'll get real lucky. The remote is a spare so things could be worse, need to fix it tho so it really is a spare instead of just looking like one. I have recently replaced the female part on the davit so I don't want to change that out to the ubiquitous 10 pin stuff I can find easily. That's three soldering jobs compared to one. This connector must exist someplace.
    Thanks again for the info Pascal.
    Regards
    Dave
  5. clovehitch
    clovehitch Member
    Chesapeake Bay
    Hello all, recently purchased a Novatec 55. It has a Quick Lift Davit that has stopped working. The cable works in and out okay but the arm will not rise. I can hear the hydraulic pump working and can see one of the hydraulic lines building pressure. I believe one of the solenoids is the issue. Can anyone provide me with a contact for someone familiar with the lift that I can talk with to see if I can figure out what is going on with the lift. Thanks in advance.
  6. geologydave
    Cape Coral,FL
    On mine they are relays, not solenoids. Black cubes about 1" square and they do fail. There are two mounted on the pump housing, try switching them. Sounds like one failed. good luck
  7. clovehitch
    clovehitch Member
    Chesapeake Bay
    I will try switching them. Thank you.
  8. Pascal
    There is a relay to engage the pump when you press a switch on the remote. If your pump runs, that relay is fine.
    the solenoid activated valves can fail. They have a manual override, in fact the whole davit can be used without the remote. Trying to remember as it has been 8 years….
    There is an access plate inside the davit housing which are two wires you can connect to activate the pump manually and once it is running you can press on the valves to activate a function.
    the solenoid valves are off the shelves and can be found but I would first check the remote itself as the wires can break or the board can corrode.
  9. clovehitch
    clovehitch Member
    Chesapeake Bay
    Yes the pump engages when a button is pressed. I will look for the access plate on the davit and check for any broken wires on the remote. Thanks.
  10. geologydave
    Cape Coral,FL
    Sorry for the really bad advice. the intent was good. Your problem sounded like what I had and the relay was the problem. The ONE relay, I had to check as I misremembered two.
    Pascal running on 8 year memory and a understanding of the circuit; impressive.
  11. Pascal
    If the pump engages then you don’t need to connect the override.
    locate the valve body and manually activate the valves while the pump is running. I think that on the one we had, it wasn’t a button you had to push on either side of each valve but a rod you had to pull.
  12. clovehitch
    clovehitch Member
    Chesapeake Bay
    Thanks, as I recall there are no rods on the valve body. I will double check when I get to the boat again. I did check the remote and all wires appear connected and the pump runs. I’ll let you know what I find.
  13. clovehitch
    clovehitch Member
    Chesapeake Bay
    Follow up,
    this weekend I removed the top plate on the quick lift and found two solenoids under the plate. The lift worked perfectly when the plate was removed. When I put the plate back on the lift it would not work. I saw there are two solenoids that have a spring loaded push top and when the plate was put back on, it depressed one or both solenoid tops. There was a missing gasket under the plate and I made a gasket out of a sheet of cork. Put it back together and it works fine. Thank you all for your suggestions.
  14. David Helsom
    David Helsom Senior Member
    Sturgeon Bay/Fort Lauderdale
    Well that’s a nice win!
  15. clovehitch
    clovehitch Member
    Chesapeake Bay
    Yes it was. Thanks.
  16. Madr
    Madr New Member
    Hot springs, ar
    Where exactly is the rubber plug at the top? Are you talking about the davit arm or the hydraulic pump? My davit squeals when I lift my tender and I can't find any way to lubricate the internal pulleys other lubricating the cable which doesn't seem very effective
  17. Offshore58
    Offshore58 New Member
    Stuart Florida
    My Quick Lift Davit 1000 cylinder failed and cant be rebuilt. I was quoted $4500 to build new one. anyone know where I might find a cylinder ?
    Does new build price sound right ?
  18. Pascal
    Which cylinder? Sounds high for the Linears but cheap for the rotation
  19. Offshore58
    Stuart Florida
    No rotation on the 1000
    Bad cylinder is for the arm lift
    4500 is for complete new cylinder build.
    Can't find anything compatible.
    Friend just replaced 2 cylinders on different make for 7600 and they were rebuilds.
  20. Pascal
    Have checked with a reputable hydraulic shop to see if yours can be rebuilt ?
