Click for Cross Click for Abeking Click for YF Listing Service Click for Burger Click for Nordhavn
PSA: descale these condensers.
Discussion in 'HVAC' started by Pascal, Jul 19, 2024.
  1. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    I believe what Maldwin is referring to is the electrosea system. Electrosea.com. Not the Raritan electrosan “poo cooker.” Would be good to know how much it would cost and any drawbacks to the installation.
    If you look at the theory of operation, it works the same way. This is why I mentioned it that way.
    motoryachtlover likes this.
  3. David Helsom
    David Helsom Senior Member
    Sturgeon Bay/Fort Lauderdale
    This is based on our 60 foot Hatteras motor yacht.
    David,
    Thank you for writing to ElectroSea.
    ElectroSea offers four ElectroStrainer models based on the current A/C strainer pipe size and flow rates.
    ElectroStrainer ES-125-Pro: 1.25” input/output strainer that treats an optimal flow rate of 17 gallons per minute. $6,250
    ElectroStrainer ES-150-Pro: 1.5” input/output strainer that treats an optimal flow rate of 30 gallons per minute. $9,495
    If you would like to move forward, I will happily connect you with the local Dealer.
    I look forward to hearing from you.
    Thank you,
  4. Charles Gross
    Charles Gross New Member
    Cape Cod
    OEM on all Vikings. Work well.
