Click for Abeking Click for YF Listing Service Click for Abeking Click for Walker Click for YF Listing Service
Propping for WOT and 80% cruise
Discussion in 'Props, Shafts & Seals' started by Tbill36, Sep 26, 2025.
  1. rtrafford
    rtrafford Senior Member
    Vero Beach
    ....and by all means, run your Cats the way that you see fit and proper to do so. You don't need anyone else telling you how to manage your systems. As a very basic rule of thumb that does not apply to DDEC's, as you advance in running time beyond 3-4k hours on any machine, you should be monitoring oil sample reports, exhaust temps, oil consumption, sounds, etc. The assembly of these points of data will help the engine speak to you in terms of when it wants a makeover. There is no magic litmus in a handbook by which to live. Two engines from the same factory run that have the same type of use and care will respond in their own way regarding longevity. For instance tomorrow morning your starboard engine could lose #1. Meanwhile Port might be just fine pushing you along for another 1500 hours.
  2. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Interesting read of this thread for sure. I run my C-18's (1136 hp) at varying RPM's based on sea conditions, time I have, my mood on any given day, etc). I find I typically cruise at 1800-1850 most often. This is 65%-70% load for me. 80% load is around 2025-2050 rpm if memory serves. I just did a 740 mile trip and mainly was around 1850 rpm most of the time. If I have lots of time I may slow way down to 8-10 knots then run them up to 80% load toward the end of my run to clear them out. I'm not worried about how many hours to overhaul. Unless I get an unusual failure (knock wood), these CATs will almost certainly outlive me. It is more important to focus on good maintenance and care then to worry about 60% vs 70% loads IMHO.
    chesapeake46, Capt Cole and rtrafford like this.
  3. Regal400
    Regal400 New Member
    Montauk, NY
    Great info shared guys much appreciated.
    I have c18s on my sportfish - just hit 4k hours
    Cruise her based on load typically it’s 76-80% anywhere from 1900-1965 rpm.
    Engines fall into a grove at 1950-1965 and overall avg fuel burn seems to be the same from 1850-1965 so sea condition permitting 1950-1965 it is!
    Love my cats
  4. DOCKMASTER
    Ketchikan, Alaska
    When you say fuel burn seems the same, are you talking about gals/mile? My gals/mile increases as I speed up but not much relatively once I get in the 60% + load range. I burn roughly .15 gal/mile more with every 10% load increase. So 80% load is about .3 gals/mile more than at 60% load. If going long distances this obviously can add up to quite a bit more fuel.
    Also curious what boat are your C-18's in and what speeds do you see?
