Click for Cross Click for Westport Click for Burger Click for CL Yachts 99X Click for Ocean Alexander
Proof that yacht design isn't rocket science
Discussion in 'Yacht Designers Discussion' started by bmattes, Mar 3, 2010.
  1. 84far
    84far Senior Member
    Brisbane, AUS
    bmattes, have a look at the following link if you want, just some ideas. A lot of these boats do reef trips every year, and some of them though being a cruiser, can also set sail/s for extra stability. Because going for a round bilge, they’re going to roll their guts out if not used right... 5m following seas can get a bit tricky (a few family boats in there). ;)
    http://www.millarsphoto.com.au/demo/category/36
    Also have you checked out pod systems (IPS)?
    Personally, I would get someone else to design and build the boat, it won't cost you as much in the long run I think, IMO. Cheers
    Far
  2. Emerson
    Emerson New Member
    Homer, AK
    Something I forgot to ask, why a Downeaster?
  3. bmattes
    bmattes New Member
    Annapolis, MD USA
    emerson- honestly I just like the way she looks
    To all- thank you for all the wise sage council. If I do decide to build a boat like this I will certainly seek the wisdom of a professional naval architect and probably use this design more as inspiration than design.
  4. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Me too, I love the look and the honesty of the design.
    http://www.huntdesigns.com/custom-over70.htm
  5. Globs
    Globs New Member
    Cambridge, UK
    The design looks nice if a little unusual. The lack of flare will tip a lot of water over the top I think, which is efficient but rather wet. I.e a flare knocks the water back - slowing you down, just letting it past like a submarine is efficient - but you need to see where it lands, crashing off the front of the cabin slows you down too ;)
    You may also want wind-tunnel testing of various square/rounder corner options of the wheelhouse to reduce its drag. Perhaps just build two competing scale models and balance them against each other in the wind - saves a wind tunnel ;)
    The way to test a hull design would be to built a 1m model of it, kit it out with some RC and test sail it in some windy chop on a lake, taking account of power usage (you can buy eagletree loggers for that).
    You will also want to visit www.yachtsurvey.com and buy David Pascoe's books about designing and building boats, probably the fastest and cheapest way to learn the things you need to, and gives you the knowledge to keep on top of any architect you may choose - if you do.
    Me? I would tend to research some well riding efficient hull shapes of roughly the size you want and copy/derive a design from that - hence taking advantage of other people having tested your hull shape for you already.
  6. CODOG
    CODOG Senior Member
    Bournemouth, southern England
    *sigh*
