Click for Abeking Click for Ocean Alexander Click for Nordhavn Click for Abeking Click for Westport
problem with capc system
Discussion in 'Chris Craft Roamer Yacht' started by noogaroamer, Jun 20, 2019.
  1. noogaroamer
    noogaroamer New Member
    chattanooga
    Its on a 1963 roamer 36ft, system just quit about a week ago. Anyone know where the hull contacts are located or common problems , its about impossible to follow wires through the boat. Is there a replacement for it. Thanks
  2. JimBauer
    JimBauer New Member
    Boat - Oakland, Home - San Diego
    steel or aluminum, what's the model number of the system
    You have to replace the part on the bottom of the hull every 7-10 years as they do wear out.
  4. noogaroamer
    chattanooga
    just had the bottom repainted, wonder if that has something to do with it. Its a steel hull. I believe its a model 34640
  5. captholli
    captholli Senior Member
    In The Bilge
    If the cathode on the bottom of your vessel was painted over than yes, that would be a problem. This cathode will look like an 6" - 8" or so flat saucer with a round metallic disk inset into the center. The disk has to be in direct contact with H-2/0.
  6. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Uh...What is a CAPC system?
  7. Capt Ralph
  8. cleanslate
    Cherry Hill, NJ
    Got it CR ! Thank you. It’s not a relevant thing to have on a fiberglass boat of any size I assume ?
    Or boat material doesn’t matter ?
  9. Capt Ralph
    Not for FRP hulls. Bronze and Stainless with a few zincs still dominate metal protection here.
    But Mercury/MerCruiser does support their own product that protects I/Os and Zeus pods using the same technology, just much smaller scale. I think it works here.
  10. rtrafford
    rtrafford Senior Member
    Vero Beach
    This. Take a look to see if the cathode was painted by mistake. Happens from time to time.
  11. cleanslate
    Cherry Hill, NJ
    Ok got that too.
    YF school is always very informative.
    Thanks CR
    I know what FRP is!! Fiber Reinforced Plastic ! AKA Fiberglass..lol.
    See I’m semi-nautical-smart.
  12. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    They won't work if you bottom paint over it. So that might be your issue.
