Click for Walker Click for YF Listing Service Click for Burger Click for Ocean Alexander Click for Westport
Port idle conking out
Discussion in 'Carver Yacht' started by tommyfmu, Jun 22, 2014.
  1. K1W1
    I would say that the "cover" mentioned here is the Valve Cover not the Cylinder Head at this stage.
    If compression testing the non firing cylinder is posing problems owing to access I imagine replacing the valve springs with the head on will not be easy either if its even possible
    Problem?? The tech replaced the plug..
  3. tommyfmu
    tommyfmu Member
    Freeport, NY
    The block was rebuilt 3 yrs ago, as well as the carb 2 yrs ago. Unfortunately the two year warranty on the block expired one year ago [of course lol].
    In my limited mechanical knowledge above, it's possible I haven't described the diagnosis really well. The mechanic, who is employed by a medium size marina in our area, is really well regarded as to his abilities for both gas and diesel. he rebuilt our stbd block last year and it's worked flawlessly.
    I'm driving her over to his facility this morning and will revert back as to the findings.
    Thanks for all the input. Tom.
  4. Chasm
    Chasm Senior Member
    You are right, valve cover makes much more sense in this context. Working on them in such an restricted environment sounds interesting in the Chinese sense. Still trying to think of an obstruction where I can change spark plugs but not fit a compression tester. Unless its a rigid one.
    Always the case if you remember the warranty. =)
    It is quite possible that something got lost while playing the telephone game.
    [Cue the usual presentation about communication issues. What I actually need, what I think that I want, what I think I've said, what I did say, what someone has heard, what someone has understood, ....]
    Maybe there was an obvious sign for a fault and the working cylinder compression test was used to rule out a global problem. Maybe there is an access problem I can't visualize.
    So there there is a moment that makes one pause and feel doubt about the situation. (Here while reading about it second hand, which does not help either.) That does not instantly mean that the mechanic is wrong, usually just that some piece of information is missing.
  5. tommyfmu
    tommyfmu Member
    Freeport, NY
    My marina's manager called me to say that the mechanic did a 'leak down' test and has determined that the valve [I'm assuming fuel input] on cylinder # 7 most likely has 'fallen in' because there's no fuel making it to the combustion chamber. Next step will be to send the 'head' out to be redone, short of replacing the block yet again. I'm waiting for him to call me to discuss.
    UH?
    Leak down on a SBC?
    I guess that could be done. Keeps that clock going..
    Lets hope again that's a broke valve spring. If the valve fell in and struck the piston (ouch), it all comes out. Could explain where the oil went.
  7. bobhorn
    bobhorn Member
    Kemah, TX
    Maybe I'm missing something here, but how does a leak down test determine if there is fuel reaching the cylinder? If it's a failed valve there is no leak down because there is nothing to leak down because there is no compression.
    Bob
  8. Maybe Knot
    Maybe Knot Member
    Nashville Tn
    If you allow anyone to talk you into machining one head and not the other, you need to run the other way.
  9. Maybe Knot
    Maybe Knot Member
    Nashville Tn
    That would be so noticeable in engine noise alone, a deaf-mute could hear it.
  10. Capt J
    Find a new mechanic.
    Your answers make no sense and the mechanic is taking you for a wild ride. If you cannot even screw a compression tester in the cylinder, how do you screw virtually the same fitting into the spark plug hole to perform a leak down test? In order to do a leak down test, if you cannot confirm you are at TDC through the spark plug hole, which is what I'd imagine because you can't even screw a compression tester in there, you'd have to yank the valve cover to confirm TDC. If you yank the valve cover, you should be able to see a dropped valve from a mile away and it would make an aweful racket as someone else mentioned. My guess based upon what you've described is that your mechanic set the ignition timing too high and you have a hole burned in your piston or burnt exhaust valve and that's why it's one of the 2 last cylinders. Usually when you melt something from too high of ignition (or poor quality gas) it's one of the two last cylinders. I agree also, both heads should be rebuilt.
  11. K1W1
    Either things are not beig explained properly by the mechanic or there is a complete lack of knowledge about the problem.
    Pull the valve cover and see if one of the springs is broken, if the collets had popped out and the valve dropped into the cylinder keep going and pull the cylinder head off.
    Do not service one head do both, if any doubt as to valve train components viability replace them all, the component cost is not huge compared to the damage that can be done by a failure and the inconvenience of this in the short summer cruising season.
  12. tommyfmu
    tommyfmu Member
    Freeport, NY
    Valve head was pulled today. Piston # 7 is showing 'dents' because the piston was lifting too high in the cylinder and snapped the exhaust valve from what they're telling me. They either could send out for the heads to be done which is a few hundred dollars plus labor, although the mechanic said he's not 'comfortable' knowing that something down in the crankcase might be broken and re doing the heads could be a waste of money if it's just going to snap a valve again. The alternative, of course is to replace the block. Again.
  13. Capt J
    AFTER, you find a new mechanic. The piston cannot lift any higher than it is normally supposed to. What it sounds like is that you had valve float due to a weak valve spring (or over-revving it) and the valves didn't close as fast as they normally should and the piston hit them.
  14. Maybe Knot
    Maybe Knot Member
    Nashville Tn
    This^^^
    It sounds like you are getting bad info. Whether from the marina manager or the mechanic, you choose. That piston is NOT going to "lift" too high. It goes up and down within the cylinder on a rod. Undoubtedly, you have "dropped" a valve somewhere along the way.
    Another thing...
    If you are paying marina rates for mechanic labor, you are paying waaay too much for parts and labor. A 350 Chevrolet is nearly bulletproof. Even though you stated this motor is out of warranty, I would go back to Grooms or Jasper, or wherever you got it and plead your case. Maybe date wise you are out of warranty, but actual hours, there is no way you could have accrued enough wear on this motor to drop a valve. While they may not honor 100% of the warranty, perhaps they will give you 50% or so off on the next purchase. Any ASE Certified technician can change it out in his off time.
  15. tommyfmu
    tommyfmu Member
    Freeport, NY
    First thing I did was discuss with Jasper, but got no where. They only go by time, not hours on the block ; trust me I pleaded it up / down / and sideways.
    The head was removed and I saw that the exhaust valve snapped off. There was some rust, and the valve was probably bent and had let sea water in. Trusting that the crankcase is ok, we're having the head sent out to be refurbished. Since the block is nearly new, it isn't necessary to send the other side out; it'll just add to the cost.
    We are paying marina rates; there isn't much of a choice unless you can send someone to me from our area. There are way too many hacks posing as 'mechanics.' The yard we use to repair and store are at least very experienced and stand by their work. This block was put it by another yard who got swamped by Sandy which is why we switched, but also found that the yard mechanic is highly respected among my most critical boating friends.
  16. Maybe Knot
    Maybe Knot Member
    Nashville Tn
    Here's a for instance...
    Shop labor rates here (non dealer) for auto mechanics are in the $100 per hour range. I have a tech that works on my cars for $40 an hr in his off time. Marine labor rates are in the same range. I just moved to a new marina last month. I backed into the slip and was greeted by one of the full-time residents at the slip. When he asked about my cruise to get there, I told him I had an engine running warm. He immediately replied that the guy who lived three slips down is an auto mechanic (working for a reputable shop) and he could get me straightened out. Sure enough, when the guy came in that afternoon from work, we discussed the problem and he agreed to work for $50 an hour. Sometimes, you just have to ask around. I assure you that your fellow boaters are not paying full freight to keep their boats afloat.
    It's all relative though. To me, a 50-60 dollar an hour savings is significant. Your income bracket might be higher, or you can manage to write it off. My marina charges 120 an hr plus tax (9%) based on a flat rate manual. They tell you that they are backed up 3 weeks and this is their busy season. My neighbor mechanic guesstimates the actual time involved and does it for less than half of their labor rate, within a day or two.
    ETA: Please understand, I am not picking on you in any way. I'm new to all of this, and just feeling my way around. Sometimes you have to do what you can. It just galls me to pay full retail price for anything.
  17. Capt Ralph
    Where did the rest of the valve go? Damage to the liner or piston? You believe a loose part is going to bounce around and not damage anything?
    Even if you spun a rod bearing, that could only lift the piston up about .0015 inch. the piston would hit the head before hitting a valve. Nothing wrong on the bottom, unless there is after damage; Yep, you floated a valve. Rebuilt / reused valve spring. Pressed valve stem guides, Rusted valve stem from sea (SALT) air coming up the exhaust system. How many shims were under that spring? Any punk can build a car engine. Mostly it works. Nobody seems to grasp a marine engine runs in a different environment.
    How hard and far is it to the next dock? The next mechanic?
    Elvis has left the building.
  18. Capt J
    The exhaust valve cannot let sea water in. If you have seawater in there, your exhaust riser or manifold is bad. If you don't find the real cause of the seawater than the same exact thing will happen. The valve doesn't just snap off and disappear. So if the valve is not 100% intact, the motor needs to be rebuilt. But you can find that out the hard way. The other head was rebuilt by the same guy with the same quality as this head, meaning it's probably junk also. Everyone here has given you the same advice, yet you persist, so. I can tell you from my desk chair that you have a mechanic that is not experienced enough with marine engines to properly diagnose and do the work.
  19. K1W1
    Sounds like a typical wobbly warranty, if the time had not expired there would have no doubt been some other reason to decline.
    Did your "mechanic" tell you that? Sea Water can only get into the engine if there is sea water in the exhaust between the exhaust valves and the injection point, not the best way to find things and as Capt J says you should check the exhaust system risers and elbows.
    The Crankcase is not normally a term associated with a SBC or any automotive engine. If you mean the cylinder block and oil pan you need to be aware that there is a lot more to this and any engine than the non moving parts. If I found an engine of unknown provenance had dropped a valve I would be checking the rest of the supposedly "rebuilt" engine very carefully indeed.
    Ignoring the other head will also add to the cost if you do not determine the actual cause of the failure.
    Did the valve hit the piston? Have you got any photos of the piston and valve you could share wit the group?
    You might be in the clutches of one right now.
    Where was your boat during Sandy?
    While word of mouth is normally a great reference tool, the messages you post here and the advice you seem to be getting would lead myself and others to wonder just how well you are being taken care of by those you seek out for assistance.
  20. tommyfmu
    tommyfmu Member
    Freeport, NY
    Conclusion
    Once again, Love me some Sea Insure: the Sea Tow insurance that is probably going to cover the cost of this due to 'mechanical breakdown' included in my policy.
    She's up and running again. I finally have the written report, as not to rely on my vague description above. In a nutshell after changing plugs and oil, did leak down test and found 100% leakage on exhaust valve #7 cylinder; disassembled engine, removed head. Sent out head to remove, grind and replace bad valves, pressure test. Cleaned block, installed head and torch. Cleaned intake and installed. Adjusted valves and installed exhaust; run up and set timing.
    My interpretive error above was that only the spark plug was found rusty; not seawater in piston.
    All replies appreciated on here, as a learning experience for any future situations. The mechanic is good, although yes the hourly is $130. My interpretation skills on engines lack; sorry Capt. Maybe Knot, I did ask my 25+ year auto mechanic about marine repairs and did get a number from him. Maybe next time, if out of pocket, I'll get an 'off hours' rate for similar work.
