Click for Abeking Click for Glendinning Click for YF Listing Service Click for Nordhavn Click for CL Yachts 99X
Overheating Issue
Discussion in 'Ocean Yacht' started by Boomer, Jun 2, 2018.
  1. Boomer
    Boomer Senior Member
    Seminole
    Haven't forgotten the pics...been having t storms the last few nights...havent been to the boat
  2. Boomer
    Seminole
    Now it makes sense...was trying to figure roven woven around the pipe and slide off...bahahahaha
  3. Boomer
    Seminole
    Well this is interesting....just got bottom redone and props repitched to 24x20p...motors ran great, no black smoke, and no overheating now...go figure....now on to the next problem...did I blow a turbo
    Black smoke?
  5. Boomer
    Seminole
    Grey/blue..and missing a lot of oil....nothing in the oil pans so it went out the exhaust
    You need to get a real D.D. mechanic out. Sounds to me like you have a cracked liner/dead cylinder.
  7. Boomer
    Seminole
    Roger that..was going to look at the turbo bearing first on the exhaust side to see if seal went...should be easy to tell if oil is coming from the manifold or it starts at the turbo
  8. MBevins
    MBevins Senior Member
    Windsor On. Canada
    As a fellow 6-71 owner you should heed J's advice. If you're experiencing what you say , you could be looking at a serious bill if you mess this up.
  9. Boomer
    Seminole
    Agreed....praying the turbo bearing seal went otherwise I am out of business for a few months while I get a rebuild
  10. praetorian47
    praetorian47 Senior Member
    Bayport, Midland, Ontario
    This just happened to me! The system was flushed 2 years ago and I just had an overheat last weekend, cracked the head. Turns out there was a ton of crap in the overflow bottle and blocked the return.
    Luckily I have friend that runs a generator company and got me a new head cheap. It should be here tomorrow so I should be up and running again this week!
    I'll be flushing both engines with water
  11. Boomer
    Seminole
    Motors were flushed several months ago...just pulled the valve cover...broken valve....this sucks!
  12. Boomer
    Seminole
    Where would the intercooler be?
  13. Boomer
    Seminole
    Serial # 6a 436025. Model #1063-5303
  14. Boomer
    Seminole
    Pics sent to your email address...last bill for injector install states M15 injectors
  15. Capt Ralph
    Got the pictures.
    I do not see any blower by-pass hardware.
    That is NOT a TIB, Just a TI.
    Without the blower bypass, this engine can not make the HP as claimed when sold to you (485?).
    Maybe, Maybe 450HP but needed the M95 injectors for that in 1984.
    This is a 1983 block per serial number.
    M15s should be just under 400 flywheel HP.
    Non of this makes a matter that you dropped a valve.
    Time for a head pulling party. That head is heavy you will need two young and stupid backs to pick it off the block.
    There just a RCH room on the head ends and must come up level with the block deck of will feel like you missed a head bolt.
    So, do what I did one time in my old hood, ask a couple of street kids if their whimps and you have a test for them.
    Oh, my back crushed and messed up doing this by myself when I was young and stupid.
  16. Capt Ralph
    BTW
    A SWVS governor and a 71 engine will pull it's heart out out to make the requested RPM.
    You may have been running on 5 and overheating.
  17. Boomer
    Seminole
    Awesome on the ti's...am actually happy to hear it...motors won't he so stressed out...maybe I got the 410 hp motors
  18. Boomer
    Seminole
    Going to do a top end rebuild to get her up and going again
  19. Boomer
    Seminole
    This is probably the longest running thread...lol
  20. MBevins
    Windsor On. Canada
    I'm betting you have 450 hp engines.
    And I'm betting you dropped the valve and have a dead cylinder so you're running on 5 cylinders. Not to be a negative guy but odds of not damaging the cylinder are probably close to zero. Unless you can rebuild yourself and based on this thread it's highly doubtful. You might as well just start shopping for the mechanic who's going to rebuild her.
    And pay to have the other head pulled and rebuilt at the same time. You"ll thank me later.
