Click for Abeking Click for YF Listing Service Click for Ocean Alexander Click for Nordhavn Click for CL Yachts 99X
Opinion on older Hatteras Motor Yachts
Discussion in 'General Trawler Discussion' started by Gary Fisher, Sep 20, 2026 at 11:28 AM.
  1. Gary Fisher
    Gary Fisher New Member
    Sunday
    564 Strawberry Banks Dr., Moneta, VA 24121
    I am looking for a motor yacht to do the Great American Loop. Minimum of 3 staterooms. I have been looking at older Hatteras Motor Yachts. An opinion?
    I remember the old H53s had a collapsible mast.
    This with fold-down canvass and lay-down antennas should get you under the low bridges.
  3. Pascal
    Very well build but like any other boat it all depends on how they were maintained and upgraded. Some have been butchered with poor electric modification or questionable ikea style interior remodel.
    + fiberglass fuel tanks, will last forever. Hulls are bulletproof. Plumbing was quality solid copper not cheap plastic.
    - : unless repowered the Detroit are getting close to
    Being obsolete Hulls are solid glass but decks were balsa cored, chances are someone drilled holes they shoudl have and they can rot. Repairable though. Typically heavy and a little underpowered, usually best operated at hull speed although they can get on plane especially if repowered.
    i ve owned my 1970 53MY for almost 25 years, repowered 8 years ago with Cummins.
    there were a number of variants incl with or without cockpits, with walk around side decks or extended house, classic 15’10” beam or wide beam.
    FlyingGolfer likes this.
  4. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    No personal experience, but they have a great rep... and boatloads of models/layouts to choose from. And support from Sam's Marine (or some such) is said to be very good.
    One reason we have no direct experience is that most of the older models we would normally be drawn to (because of layout) are also the models with 2-stroke DDs for power... and a combination of 12/24/32VDC electrical systems... and ladders to the bridge (instead of stairs)... and cost (versus our budget). None of those individually would maybe put me off, but the combo gets a bit much.
    And then what Pascal said: previous maintenance would be critical and maybe potential upgrades (both what and how) would be a thing too.
    -Chris
    The older Hatteras MY's were built very well, as Pascal eluded to. Fiberglass fuel, waste and water tanks, copper freshwater plumbing, good electrical etc. The split engine rooms, while easy to get around in, lead to getting smells throughout the boat, exhaust smells, leaked oil smells etc., the bilges travel through the entire boat so need to keep them clean. The decks were Balsa cored and rarely, but I have seen it some water intrusion and an issue on a boat here or there.
    They boats had a lot of room for their length, are a very good head sea boat. They are very tall with a lot of weight above the water line and tend to roll in a beam sea. They're also very thirsty if you push them at cruise speeds, but very efficient at hull speeds. The 2 cycle Detroits are more efficient at hull speeds than newer 4 cycle engines, but every 4-6 hours they need to be run at cruise for 20-30 minutes to clean them out. The onan generators most were equipped with, are impossible to get parts for and need to be replaced.
    The detroits are really past their day, parts are getting hard to come by and mechanics that know how to work on them even harder to come by.
    They're good boats, but need to know what you'll be dealing with.
    Many of us still luv and own ole boats.
    <--- is a 1978, 58x18 Bertram MY. Built very similar to ole Hatts.
    We lived on her for many years and have owned her for 22 years now.
    From Jax, many Bahama & Keys trips.
    Back then, these ole boats were built of an ever evolving material called fiberglass. Nobody had a clue how long it would last so lay more in/on.
    Fuel was cheap then.
    Bomb proof hull? Yes..
    High maintenance? Yes..
    Old Detroits? Yes..
    Old hardware and fastenings? Yes..
    Draws blood while working on her? Yes..
    Economical to operate? Heck No..
    Something you need to really understand and be honest with yourself; Are you a plumber? Are you an electrician? Are you a carpenter? Are you a painter? Are you a mechanic? Can you really operate a big ole boat?
    Something else to think about,,,,, another pontoon boat made the loop.
    But even more; https://brobible.com/culture/article/robert-youens-great-loop-world-record-jon-boat/
  7. rtrafford
    rtrafford Senior Member
    Vero Beach
  8. Capt Ralph
