Click for YF Listing Service Click for Abeking Click for Mulder Click for Ocean Alexander Click for Westport
No Power At Panel
Discussion in 'Sea Ray Yacht' started by Worthy vessel, Dec 6, 2022.
  1. Worthy vessel
    Worthy vessel Member
    Sarasota
    We have a 2009 Sea Ray 36 Sedan Bridge diesel- Onan generator
    Can not get power to the Generator to start it. Solenoid on power panel for generator shows power but switches for generator do not. Batteries are good. There must be an additional switch somewhere.
    Help
    Doug
  2. Pascal
    Many generators have a DC circuit breaker on the generator. Check that.
  3. Worthy vessel
    Sarasota
    There is no power to either switch. (On the generator or panel)
  4. Worthy vessel
    Sarasota
    BTW
    I was winterizing the boat had just started all 3 engines, then winterized the main engines and when I got to the gen it had no power.
  5. Worthy vessel
    Sarasota
    If I take out the impeller can I pump antifreeze thru the engine thru the strainer ?
    There is a breaker switch or pop out button on the gen-set panel.
    A DVM to the starter will verify if there is B+. There may be a large fuse from the starter to the control box back there also.
    Your winterizing in Sarasota?
  7. Worthy vessel
    Sarasota
    Sorry, the Sea Ray we keep on Long Island NY
    But we are in the market for a 45-55 boat for Sarasota.
  8. Capt Ralph
    If you have a water lift motor, NO.
    If you drain your muffler and pump AF slowly thru, then this can work.
    On a water lift gen-set muffler, water may fill back to the engine if not running.
