Click for Burger Click for Burger Click for Glendinning Click for Abeking Click for Cross
News: Vybe Yachts Vybe 43 Power Cat
Discussion in 'Latest Catamaran Launches' started by Yacht News, Aug 16, 2026 at 11:05 AM.
  1. Vybe 43 Power Cat
    Another relatively new name in the business is Vybe Yachts and they have their Vybe 43 power cat, a yacht that has been created as a no-compromise between style, volume and performance. Cantiere del Vybe is the actual name of the shipyard that is behind the Vybe 43 power cat. The dimensions are operator friendly and allow for berthing in a similar monohull footprint at the marina. The simple dimensions are 12.67-meters, a 3.97-meter beam and a 1-meter draft.
  2. The yacht is performance-oriented with a standard pair of engines being offered as well as a an optional pair should owners want even more speed from this power cat platform. Standard are dual 480 horse power Volvo Penta D6s. The option involves a pair of Mercury V12s that are 600 horse power. With these, top speed is approximately 53-knots under light-load conditions. However, with the standard engine set, top speeds are around 46-knots.
  3. Up to 14 passengers can be onboard and with a maximum of 1,900 LT of fuel that can be stored, 350 LT of fresh water capacity, this vessel is more than a weekender platform. In terms of construction the Vybe 43 power cat is made with vinylester-infused composite sandwich, reinforced with carbon fiber in specific areas to address structural integrity and stiffened with longitudinal and transverse framing.
  4. The design on both the exterior and interior is by Abbasli Design while Naval Architecture is attributed to Adam Younger. In the hulls there is not one but two master suites both with ensuites accompanying. The interior work is also finished out with finishes and fabrics from Loro Piana and Foglizzo which normally is seen on larger yachts. The Vybe 43 is just to start of their new line with another three models in the Vybe series expected to come in the future. Future models include the Vybe 53, 66 and 77.
    Cantiere Del Vybe
    Via Carriona, 201
    54033 Carrara MS, Italia
