Click for Northern Lights Click for Burger Click for CL Yachts Click for Westport Click for Abeking
News: First Custom Line 120 Under Construction
Discussion in 'Ferretti News & Launches' started by Yacht News, Nov 24, 2016.
  1. First Custom Line 120 In Build
    Italian brand Custom Line announced that it has the first hull in the brand new Custom Line 120 series under construction. In fact that first hull is due to be launched in the Summer of 2017. The GRP-made vessel showcases a design externally and internally by Francesco Paszkowski. The craft is being built on a semi-displacement hull expected to help her reach a 25-knot top speed using twin MTU 16V 2000 M94s.
  2. On the interior of this first hull, accommodation appears to be set up for ten guests. The arrangement is for two twins and two doubles (serving as VIP-grade suites) on the lower deck along with the full-beam master suite on the forward main deck. Seven crew members can be slept in four cabins. According to the renderings, the interior appears to follow an earth toned palette with wooden floors and splashes of accent colour in accessory pieces like throw cushions and comforters.
  3. This Custom Line 120 has the capability to store as many as three tenders onboard. The main tender storage area is in the transom while the secondary area is actually in a fore deck locker below the alfresco relaxing area on the bow. Custom Line spoke about the design and said “the profile is sleek and powerful — strong lines running from bow to stern give a more aggressive and dynamic look even while in port or at anchor.” Views from the interior should be nice particularly from the main saloon region. With large window heights and purposeful lowering of the bulwarks on the outside, the connection to the sea visually should be easily maintained. This craft is a performer and won't be known for traveling great distances but if you need to go a bit further than usual, dial her back to a continuous 11-knots and a range of 1,050 nautical miles can be realized.
    Ferretti Custom Line
    Via Ansaldo, 5/7
    Zona Industriale Villa Selva
    47122 Forli
    www.ferretti-yachts.com
