Click for Ocean Alexander Click for CL Yachts 99X Click for Delta Click for Northern Lights Click for Walker
News: Admiral Prepares Launch Of 55M "Geco"
Discussion in 'Admiral Tecnomar Yachts' started by Yacht News, Jun 3, 2020.
  1. 55-meter "Geco" About To Launch
    If all goes according to plan, the Italian yard Admiral will launch the 55-meter "Geco" tomorrow (June 4th). Geco is a member of Admiral's so-called S-Force line. Her outdoor areas will be notable when the yacht is fully completed. Significant exterior space has been dedicated to the guest experience. A touch-and-go helipad sits on the bow but when not in use it becomes more real-estate for guest lounging. The opposite end of the yacht is also catered to guest use with dual stairs descending from the aft main deck to the swim platform. One will find on either side comfy seating and lounging pads which take in the vista at the waters edge.
  2. Onboard Geco there are six cabins available for up to twelve guests. The general decor theme around the yacht is creme and beige tones reflected in the cabin's color palette. Two doubles, two twins, a VIP and a master suite are fitted aboard. Outside of the private guest cabins, guests will likely relax in the main salon onboard as rendered below. Similar tones and colours are expected in this room where stone, timber and upholstery come together in the most luxurious manner.
  3. Performance is assured by a pair of CAT C32 ACERT engines which are expected to reach 18-knots top end. You will find a spacious garage that can host a tender of 8-meters in length and other forms of fun in the water. A Jacuzzi is also available for guests on the sun deck along with space for a few pieces of gym equipment.
    The Italian Sea Group
    Viale Cristoforo Colombo, 4
    54033 Marina di Carrara (MS)
    www.******************
