Click for Walker Click for CL Yachts 99X Click for CL Yachts Click for YF Listing Service Click for Delta
New to me Viking
Discussion in 'Viking Yacht' started by Jeremyvmd, Jul 26, 2021.
  1. bayoubud
    bayoubud Senior Member
    Florida
    The OP's boat is a solid bottom, any wet core areas would be from the waterline up. A lot of builders were using balsa back then before foam coring. Most are now using resin infusion or vacuum bagging methods when coring, even on cored bottoms which now they claim is ok. All it takes is a unsealed fastener that penetrates the fiberglass coring, especially balsa and plywood. Best to monitor where something is fastened to the cored fiberglass with screws and bolts for moisture. Glassed wood stingers and bulkheads in the bilge are often neglected.
  2. vds1968
    vds1968 New Member
    point pleasant beach NJ
    I have a 1991 45’ same plan as you do
    The boat was repower Ed by the previous owner
    I spent the first winter replacing all the thru hulls bildge pumps and hoses and re bonded the entire boat so basically everything below the water line
    Also rebuild the interior make all new tops and some cabinets installed a 50” tv down behind the dinette remuved the washer dryer and made that a rod locker
    Last winter installed all new heat and air and replaced all the ductwork with insulated ductwork. Also finished amtico flooring in the galley companionway head and staterooms
    Also had teak covering boards installed
    This winter plan on doing refrigeration in the cockpit and will repair a soft spot I found on the bridge
    The eventual plan is to glass in the window frames and repaint the entire boat also may reconfigure the bridge
    Reach out to me if you have any questions that I may be able to help with
    cleanslate likes this.
  3. Jeremyvmd
    Jeremyvmd Member
    Williamstown Nj
    Damn that’s a lot of work you have done. Any pics?
  4. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    I to am a 1968; I think your crazier than me !!
    Lol.
    Nice and proper work( I can tell)!. Good job, it’s not easy.
    It sure is an awesome obsession, boats and boating that is . But we/you do have to be a little sick in the head!
    Right ? Work , work ……work.
  5. Aaron McCann
    Aaron McCann Member
    Oregon
    Congrats on the new boat!
  6. BigChief
    BigChief Member
    CT
    Congratulations I had a 1985 41 with that set up and the salon was huge. We loved that boat and did a lot of traveling with it. As far as coreing issues keep an eye on the the pulpit caulk seam, Of course the hatches and railings. Up inside the wings are some drains and and the Chase for the wiring down into the salon. make sure that's sealed up well and the drains need to be clear which let the water out towards the back of the overhang so the water doesn't sit up inside the wings. I do not believe there is coring anywhere below The rubber rail.
