Click for YF Listing Service Click for Ocean Alexander Click for Nordhavn Click for YF Listing Service Click for Westport
New fridge for 1987 3207
Discussion in 'Carver Yacht' started by iceman3500, Mar 20, 2014.
  1. Old Phart
    Old Phart Senior Member
    I dunno
    Frictions tends to cause wear.
    Velcro strip between plywood and stringers?
    Sticky Back? Fasteners | Adhesive VELCRO® Brand Products
  2. Monepit
    Monepit Member
    Evansville, in
    2awg is a little small. You should have at least 1/0. Small wire is the most common inverter problem. If you don't have much load it will work. But 2 won't do it if you you have a lot of load and will mostly hurt you for start up load.
  3. Pcomt
    Pcomt New Member
    Sidney bc
    I am really interested in this thread as we want to add a freezer to our 3007 aft cabin, mostly to freeze all the fish we plan on catching ;)
    I have purchased a 3000 watt modified sine wave inverter (before I read this post) with the intent on using it for other loads, and have been looking at a 12 volt freezer. (This is fairly expensive)
    I was told that compressor freezers do not work well with a modified sine wave. If they do work well, then we can save a lot of money by purchasing a small 120vac freezer and plugging it into the inverter.
    So, can I run a 120vac freezer on a modified sine wave inverter?
  4. Old Phart
    I dunno
    An interesting read.
    FAQ Inverters
  5. Pcomt
    Pcomt New Member
    Sidney bc
    Thanks for the link.
    I see that running a freezer with the modified sine wave will damage the compressor over time.
    I think we will continue to look at 12vdc freezers.
    Peter
