Click for Walker Click for CL Yachts Click for Abeking Click for Westport Click for CL Yachts 99X
New Design: Admiral 73-meter
Discussion in 'Admiral Technomar News & Launches' started by Yacht News, Apr 9, 2009.
  1. Admiral Showcases 73-meter Flagship Design​
    The Admiral 73 is a new project that builds upon the experience gained with the design, construction and delivery of the first Admiral 54-meter, "Sea Force One". It (Admiral 73) is also a progression and evolution in design through the 54, 58, 64-meters. The new Admiral 73 is the result of a co-operation between AMY - the joint venture between Cantieri Navali Lavagna and Cantieri T. Mariotti - technical department and Luca Dini Design studio.
    Admiral 73 spreads over 5 decks and it really is astonishing in width: more than 13 meters large. Its external lines appear none-the-less slender and slick thanks to a tailored attention given to heights and to an accurate study of proportions.
    As far as interiors are concerned, the additional deck and the hull’s width of this yacht, lend themselves to an ample range of options for the arrangement of space. A keen attention was devoted to the comfort of guests on board thanks to accurate studies made on noise and vibe’s reduction.
    With its steel hull and aluminum superstructure, the Admiral 73 reaches a total speed of 15 knots. Propulsion is via an azipod system: two diesel Caterpillar C 32 generators feed electric power to two Shottel Azipods. Such system assures that a motionless position is kept without anchorage, as well as allowing precise maneuvering in tight areas.
    And all of it, in utter quiet. By presenting series Azipods, AMY once again affirms how attentive they are to the latest advanced and most sophisticated technologies while being in no way remiss of environmental respect. The International Certification of Ecological Compatibility, characteristic of the entire Admiral line, assures compliance with the strictest regulations in terms of environmental protection while in no way compromising on the freedom of navigation.
    Specifications:
    LOA: 73.00 M
    BOA: 13.20 M
    F/L draught: 3.50 M
    Displacement:1500 t
    Fuel:190,000 LT
    Fresh water:55,000 LT
    Engines: 4 X Caterpillar C 32
    Speed: 15 knots
    Range: 5,000 NM
    Builder: Admiral (CNL)
    Admiral Mariotti Yachts (AMY)
    Via Visconti di Modrone,
    38 - 20122 Milano - Italy.
    Ph.: +39-02-76006601
    http://www.cnl.it/
