Click for Burger Click for Delta Click for Northern Lights Click for Furuno Click for Mulder
Need A/C help
Discussion in 'HVAC' started by Boomer, Jul 7, 2020.
  1. Boomer
    Boomer Senior Member
    Seminole
    Ac stopped working...when I turn it on, the fan runs and when the compressor kicks in, it pops the breaker on the power pole...pinellas county florida...any ac guys in the area to diagnose and fix/replace?
  2. dewald
    dewald Member
    Treasure Island, Florida
    Give Bimini Marine Air a call, ED Thomas, great guy.
  3. Boomer
    Seminole
    Thank you sir! AC worked on Friday morning...Saturday the boat was hot and breaker tripped...not the water pump either..switched do them out
  4. dewald
    dewald Member
    www.Biminimarineair.com should have given you the web site in first post. Check your sea strainer, cleaned mine about 2 weeks ago, was getting kicked off with HP alarm. Was in the bilge today, checked the strainer and it was a mess. Tampa Bay is hot and things are growing.
  5. Boomer
    Seminole
    Strainer is clean.. that was my first thought
  6. NYCAP123
    Filter clean? Compressor iced?
    Compressor is most likely fried......can you put an amp meter on the a/c wire and see what it's drawing........Sure sounds like a locked compressor to me.
  8. Capt Ralph
    Hang on.
    Just had another call last week and all thought the compressor locked up. The start Cap blew. Breaker lasted about 1/2 second and popped.
    Sadly, the trouble shooting with a clamp on amp meter takes some time to get the feel of it.
    The only thing you can do is open the condensing controller box up. That stupid box with all the wires going to it.
    Should be 2 capacitors in there. Look at the cap tops. Look really well at the smaller one. Is it clean and shinny as new or dirty with s**t blown every ware?
    Take some pictures and send them to me.
    Just discovered the Ace hardware shop in East Palatka has an inventory of Caps on the back wall. F M
    BTW, next call, same issue. It was the compressor. Took 30 minuets to confirm with my current clamp, DVM and hammer.
    Lets hope for the best for you. You have been thru enough and I have no fish in the mail yet.......
    Humm, What does that mean???
    ,rc
  9. Boomer
    Seminole
    And yes the bay is getting bad...barnacles are growing quickly
  10. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    On the off-chance... remove the wires from the compressor terminals, clean up the posts and the wires, put it all back together and see if that helps. Worked for me, once... and you might get lucky. The wiring didn't show any visible signs of corrosion but...
    -Chris
  11. Boomer
    Seminole
    Filters and strainers are all good...no ice anywhere...will definitely check the caps though...great thought!! Sorry...no fish by yet....
  12. Boomer
    Seminole
    Will check the terminals also...thanks for the ideas
  13. dewald
    dewald Member
    Give me a call, I can tell you some of the things Ed told me to check before he comes out. I - Ed replaced one of my condenser units in 2018.
    David
  14. Boomer
    Seminole
    Hi david... he is scheduled for next week...also checking the caps and terminals tomorrow night...I might get lucky...he did say my old marvunit is no longer in business
  15. Capt Ralph
    Split or Self contained?
    I still have 2 self contained MarvAir units in storage.
  16. Boomer
    Seminole
    Split...compressor under back deck and air handler in the salon ceiling...16000 or 18000 btu I believe
  17. Pascal
    Lack of water flow will cause a high pressure error not trip a breaker.
    mid the breaker trips as soon as compressor starts it is easy a fried compre$$or or a fried start capacitor
  18. Pascal
    Marvairs were very good. Made in the Us until domestic bought them out. I had bought one a few years ago when one of my old split had failed. I used for a a year before getting my chiller system installed then sold it to a neighbor. It s still ticking.
  19. Dj239
    Dj239 Member
    Ft myers
    Take out the caps and check the uf with meter. If cap is bad it will show low. Make sure cap is discharged before testing
  20. rtrafford
    rtrafford Senior Member
    Vero Beach
    I've seen this cause a breaker trip, too. Typically, you're right, the high pressure safety trips, but the breaker will, too, if sensitive enough. I've installed the sea water pump through a contactor to allow for easy engagement of the pump to verify flow apart from the compressor as well as for general maintenance.
