Click for Delta Click for Glendinning Click for YF Listing Service Click for Abeking Click for Ocean Alexander
Navigator Window Trim
Discussion in 'Technical Discussion' started by gr8trn, Jan 15, 2017.
  1. gr8trn
    gr8trn Senior Member
    OR/WA/CA/BC
    So did you go with new Fritted glass or did your contractor bake a Frit pattern onto the existing glass?
  2. Capt Cole
    Capt Cole Member
    Pittsburg CA
    If you look at post 15, I gave a fairly detailed explanation of the solution I opted for. The ceramic frit process was too expensive (around $12K) for just the one window. I'm pretty sure the price would come down per window if I were doing several panels. A lot of the cost had to do with setting up the equipment for a "one off" project. I am very happy with the material we applied to the outside of the glass providing very good UV protection for the adhesive.
    Good Luck with you project
  3. gr8trn
    OR/WA/CA/BC
    I did get confused when you brought the Frit up again, thanks for your response. So glad all is well. Now we wait for reasonable temperature for the project.
    Thanks so much for your assistance.
