Click for Ocean Alexander Click for CL Yachts 99X Click for Northern Lights Click for Nordhavn Click for Westport
MTU Series 60 Won't Rev Over 1500 RPM
Discussion in 'Ocean Yacht' started by alvareza, Aug 10, 2019.
  1. Capt J
    Sounds good. If the gaskets were really dried out, I'd plan on doing the other engine too. Chances are the gaskets on it aren't far behind it, I'd also do valve adjustment too.
  2. alvareza
    alvareza Senior Member
    Scituate MA
    First, thank you all for the advice, made it much easier for me as a first time sportfish and diesel owner. Definitely an educational experience for me.
    Both engines had leaks at the intake manifold gasket and were done. The tech’s computer was not very helpful. He found the leaks by putting in earplugs and his earmuffs then feeling around the engines as I ran the boat as high as it would go.
    I would not have known where or what to feel for nor have been brave enough to crawl outside the engine while someone I did not really know ran the boat. Definitely earned his wages.
    He also found some impeller pieces at the heat exchanger intake in one engine and an anode from the fall service that had come loose again in the heat exchanger intake of the other engine. I will be doing anodes myself this fall.
    How often do you guys change the impellers?
    I do every 2 years or 300-500 hours on the engine impellors...…..Depends on what size they are. One generators, I do every year or 200 hours.
  4. Beau
    Beau Senior Member
    Beaufort, NC
    There is a whole thread we just did a month or two ago on this very subject. Wish I could remember the heading....
  5. leeky
    leeky Senior Member
    Florida
