Click for Ocean Alexander Click for Glendinning Click for Westport Click for Nordhavn Click for CL Yachts 99X
MTU oil?
Discussion in 'Engines' started by CTdave, Aug 4, 2010.
  1. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    LOL! Good one!!:D
  2. CTdave
    So, I ended up speaking to both Johnson & owers and Atlantich DDA/MTU.
    Both said 15/40 MTU oil which I did put in. Same thing goes in the ZF gears.
    In the future, I think I'll be just fine using Rotella 15/40
    The Florida Detroit Diesel Rep here told me not to use Rotella as he's seen engines with excessive piston ring wear on yachts that have used it. This was when we did the engine survey/seatrial for the extended warranty plan on a set of 2006 MTU series 60's. Take it for what it's worth.
  4. Highlander
    Highlander New Member
    Milford CT
    I'm a fan of Amsoil too but Yanmar didn't want synthetics at all (1999)
    so I went with the best non synthetic according to Amsoil tests.
    Mobil Delvac 1300 15-40 was a step above all the other diesel oils.
  5. K1W1
    This is the basis for CAT DEO, I remember when it first came out that the CAT Synthetic Oil Spec Sheet was an exact copy of a Mobil 1 Spec sheet with any reference to Mobil by name replaced with the CAT blurb.
  6. Donzi 54
    Donzi 54 Member
    Point Pleasant, NJ & Morehead City, NC
