Click for Westport Click for Ocean Alexander Click for Ocean Alexander Click for Abeking Click for CL Yachts 99X
MTU 16v2000 diesel longevity and overal comments
Discussion in 'Engines' started by ArielM, Nov 28, 2014.
  1. captholli
    captholli Senior Member
    In The Bilge
    No cooling water... Should have had enough alarms to look like a Christmas tree prior to a fire though.
    Lack of raw water flow
  3. Jorge Lang
    Jorge Lang Senior Member
    Why buy new when they can be rebuilt from the block up?
  4. Pascal
    I know I m reviving a 9 year old thread but some of the members are still active.
    Friday during routine bilge cleaning and checking we found some rust under our port 16V2000 M91. Came out of the raw water pump which had salt residue… yep, leaking pump. That pump is still under warranty and was replaced during the rebuilt. No damage to the engine as the weep hole wasn’t obstructed yet… just hoping the pump is in stock
    not impressed by MTU. Same story with a failed starter last year, also under warranty. Btw these MTU starters are now made in china…
    compare this 13 previous years and 7000+ hours running 3412Es and C32s… never replaced a raw water pump and only replaced one starter!
    I've found that everything bolted to the MTU's are cheap quality......starters, alternators, pumps etc........that and the millions of alarms that go off on them from the myriad of sensors.
  6. Pascal
    Yeah… we also had a new MTU starter fail within months of the engine rebuild. Turns out they are now made in china… thankfully I had the original starter rebuilt, much better quality.
    according to my mechanic, if a leaky pump isn’t caught in time, the salt will clog up the weep hole and water will be pushed into the engine thru the seal… apparently this what had happened to our port engine a few years ago resulting in bearing and crankshaft damage
    needless to say, we ll be paying more attention to the pumps from now on
  7. Pascal
    Not even two years and 500 hours…. the port engine MTU 16V2000M91 raw water pump has failed again. Found a small leak and salt in the weep hole.
    ridiculous… these things must be made out of chineseum. Despite the astronomical price.
  8. Capt Ralph
    Like that starter issue, did you keep the old pump.
    Time to find some machine shop to reseal those darn things.
  9. Pascal
    I didn’t. I ll Check with my MTU guy to see if they can be rebuild.
  10. Capt Ralph
    Rebuilding MTU raw water pumps has been an issue on YF for a while now. Please update us if things have changed and these pumps have become serviceable recently.
