Click for Abeking Click for Cross Click for Delta Click for Northern Lights Click for YF Listing Service
Marineair chillers replacement or repair
Discussion in 'HVAC' started by Pacmac, Aug 10, 2016.
  1. Capt J
    That's the problem with chilled water. One broken fitting and no a/c throughout the entire boat...... it should be pretty easy to fix it where you're at......even if you have to hose clamp hose over the two pipes or put a fitting in.
  2. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Also, you need to drain and re-fill the system with proper Glycol solution. You get below freezing in Vancouver in winter and if you have been filling the system with water you will have frozen pipes and then really have a mess on your hands.
  3. Pacmac
    Pacmac New Member
    Vancouver b.c. Canada
    Thanks for the heads up. We will do that.
