Click for Abeking Click for Nordhavn Click for Westport Click for YF Listing Service Click for Ocean Alexander
Main engines sea strainer hoses
Discussion in 'Technical Discussion' started by Dennis Elliot, Sep 3, 2026.
  1. Dennis Elliot
    Dennis Elliot New Member
    Cape Coral Florida
    Hi.
    Is it necessary to have wire-wound hoses from the main seawater seacocks to the seawater strainers? I know that if there are any tight bends in the hose, it might kink without the wire, but if the bends are smooth, would it be alright to use soft-wall hoses for this job?
    Thanks.
    Dennis
  2. Pascal
    I wouldn’t. The hoses for your mains are the biggest on the boat… why cut corners there. Get the best hose you can like Trident. Not some off brand Chicom crap
  3. Capt Ralph
    Low pressure (suction) requires wire reinforced hose to ensure nothing can callaspe in.
    After the raw water pump, not required.
    After a few years of boat management and service, I was amazed to find this and old hoses sucking in and restricting flow.
    The hose from the thru hull/strainer/raw pump needs to be the best hose you can find. Below the water line also dictates this. Don't cheap out on this.
    As long as I'm spending your money; Don't cheap out on the hose clamps.
    Remember, this is hardware below the water line.
  4. Pascal
    Yep… quality solid band, not perforated, clamps or better on larger hoses T-clamps
    Trident or Sheilds and absolutely wire bound. Corregated wire bound IF sharp bends are needed.
