Click for Glendinning Click for Delta Click for Burger Click for Ocean Alexander Click for Northern Lights
Let’s Talk STARLINK
Discussion in 'General Yachting Discussion' started by DOCKMASTER, Jun 19, 2022.
  1. German Yachting
    German Yachting Senior Member
    West Coast
    I think if you want in motion you might need to change if you go over a certain speed.
  2. Pascal
    It seems like the marketing department at starlink can’t make up its mind and changes things every few weeks.
  3. Scallywag
    Scallywag Member
    Islamorada FL
    This is the only reason I haven't signed up for service yet. There isn't absolute clarity on what I'm signing up for.
    How easy is it to switch on and off service? Thinking about keeping my dirt cheap unlimited wi-fi service for when I'm stateside and switching on for a month or two at a time when I'm actively cruising the bahamas.
  4. Pascal
    It a as easy as going in the app and hitting the pause button. Pause only works for longer time frames though, as the pause only starts at the next billing cycle. We have both the original RV dish and the newer HP dish on board, I have paused the RV to keep it as back up.
    Scallywag likes this.
  5. Pascal
    There has been a lot of discussion following starlink announcement yesterday about cracking down on in motion and ocean use starting may 9th. The website has finally been updated with some much needed clarifications and definitions. See Screenshots below.
    At this point, I order to use your SL on the “ocean” it looks like starting may 9th you will need to be on a roaming plan incl regional at $150/mo and when needed toggle the Opt In Priority Data at $2/gb (minimum 24hours) They also offer larger plans but this is the most practical for most users.
    Their definition of land includes all areas marked available, coming soon or wait list. Most of the islands and cays of the Bahamas fall in that group. As long as you are within the hexagon shaped areas you do not need to use OIPD. No change.
    Between areas of the Bahamas as well as within three zones in the exumas, Starlink will only work if you toggle OIPD.
    So for instance when anchoring between Cambridge Cay and Farmers, you will not have to toggle OIPD on. But if you want service between Farmers and Barraterre, you will need OIPD toggled on. Then when you get there you can turn it off again.
    In order to use Starlink underway, in motion, you need the $2500 High Perfomance dish. The RV/Residential dish will no longer work in motion
    C9C2E4CA-71CF-488A-93A2-91946D350656.jpeg CBBF443F-7051-4856-B4AB-F6E80AD983A7.jpeg E4E092B4-4F56-43F4-92E3-4DE495DAFFA0.jpeg
  6. rtrafford
    rtrafford Senior Member
    Vero Beach
    Are you having any issues with the HP dish mounted on your hardtop and radar interference?
  7. GPO
    GPO Member
    Ladysmith, British Columbia
    Great post Pascal!
    Some observations from the Pacific side. In the PNW, specifically Puget Sound, Starlink worked wonderfully during a recent week long visit.
    As a Roam customers I guess we’ll find out when it will be necessary to opt-in to purchase Mobile Priority Data (charged per GB). Appears that it will be straightforward to toggle between opt-in and opt-out.
  8. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    I have SL with the $2500 antenna and the $150/ month plan. I have not been to the boat yet and used it. I am also not very literate with technology. Can I make phone calls with just SL or will I need Skype or WhatsApp?
  9. Pascal
    You can use Wi-Fi calling on your phone without having to resort to third party app. I hate WhatsApp…
    motoryachtlover likes this.
  10. German Yachting
    West Coast
    They already removed the definition of the ocean area FAQ but from a technological perspective, I don’t think it’s very efficient for them to geofence outside the hexagon. Curious how in motion will also be enforced. From current experience, they seem to have a 9/10 knot cutoff so the trawlers or if your traveling slow should be fine.
  11. Pascal
    Yea I guess some lawyer at starlink spotted a word he didn’t like …. I guess the part where it said “coming soon” was “ocean” since it encourages people Tobias SL where it’s not legal yet.
    the slow speed cut out varies from user to user. In our case even going 6 kts out the marina channel and just touring around under 10kts was enough to shut down. That’s why I switched the the HP in motion dish. I m sure that’s going to be enforced since they offer the HP dish
  12. sdonx
    sdonx New Member
    SE Massachusetts
    Bit the bullet and ordered the Maritime setup. I will let you guys know how it works out.
  13. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Got my STARLINK up and running yesterday. Getting 170 mbps in the salon and 120 in the master strm. The router is up on the flybridge inside the bridge console. Too much of a pain to run the wires down further and am happy with those speeds.
  14. zen
    zen Member
    Delray Beach
    Which antenna is everyone buying - $600 or the $2500?
  15. Pascal
    If you want to use it underway the only antenna that’s approved is the $2500 High Performance antenna. SL has been sending emails to folks using the RV antenna while underway saying their warranty could be voided and their account could be terminated. Apparently authorities in various countries are putting pressure on SL to enforce the TOS.
    some boaters, especially slow boats, still have good luck with the RV antenna underway, others no.
  16. German Yachting
    West Coast
    There’s a discount right now to get the HP for $1900
  17. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    I am currently 300nm east of Bermuda and Starlink Maritime speeds are 220Mb Down and 60Mb Up. We had a Zoom call yesterday with no issues
  18. motoryachtlover
    smithfield, VA
    Crossed to the bahamas yesterday and had cell and wifi the whole way. Maybe I am old but pretty amazing to me.
  19. Pascal
    Cellular while crossing ? Even with a cell booster we always lost signal 12/15 nm off shore till about 10nm from Cat Cay or Bimini. Same on the bank… 60 nm dead zone between east of Cat till the NW Channel unLight.
    Cellular service has been getting worst in many areas of the Bahamas due to congestion
    As to Wi-Fi service, I gave up on that years ago, even with the high end Wave system. It would work in a few marina but that was it.
  20. motoryachtlover
    smithfield, VA
    Yes cellular on the way across. It is possible that I had it from land but I don’t think so. Had internet for sure, as I was looking things up. I was using Starlink for the first time. You got me wondering about cell though. I posted this about 15 miles west of northwest shoal heading towards chubb
