Click for Walker Click for Abeking Click for YF Listing Service Click for Glendinning Click for Burger
Let’s Talk STARLINK
Discussion in 'General Yachting Discussion' started by DOCKMASTER, Jun 19, 2022.
  1. Capt Ralph
    Old radar power supplies, motors and magnetrons can radiate noise that can mess things up.
    Think compass safe distance, plus.
    So not necessary in the array beam can effect it.
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    Any input as to the change to the stationary antenna relative to radar height impacts? Shuffling the deck here with a bridge redesign and hardtop, so I need to make adjustments to the layout on the mast…
    Does the new antenna design find less radar impact?
  3. Pascal
    Ours is a few feet from the radar on the skylounge roof but lower no issue. Vertical separation is important
  4. rtrafford
    Vero Beach
    Vertical separation, agreed. What do you estimate as your gap?
  5. Pascal
    Not sure, 2’ maybe.
  6. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    My Starlink antenna is above my radar. Not by a lot. Maybe 1' or so.
    LM Viking likes this.
  7. rtrafford
    Vero Beach
    Cool. Sounds much less sensitive than the first antenna.
  8. Capt Ralph
    Open array have a flatter beam angle, say 3 to 5°. Raydomes can exceed 10°. You can figure that spread when trying to adjust for vertical clearance.
    less sensitive; I really think nobody really knew (or knows now) what effect marine electronics has on the StarLink antennas.
    I typed before; out of the beam and compass safe distance as anything else should be safe.
    My friends Fixed StarLink is 3 feet away and 1 foot lower from his Garmin Raydome. Probably gets some radiation. No issues at all.
  9. rtrafford
    Vero Beach
    My first attempt with the original antenna was pole mounted around 2' above the open and around 1' above the doppler. Doppler was no issue, but when the 12Kw cranked up I lost the sat. Increased pole mount to around 4-5' above, and no issue at all. But I think that was a more complex antenna not intended at all for these conditions. I think the new is "less sensitive" to interference. I'll just get ahead here and rig a stick mount to test the elevations before the big work commences, to be sure that I can land it where I currently intend. I'll keep it high on the mast, and given the reported 2 feet I don't see an issue...but a quick test will save frustrations.
    Capt Ralph likes this.
