Click for Cross Click for Walker Click for Abeking Click for Burger Click for Delta
Kohler Generator won't keep running
Discussion in 'Carver Yacht' started by JimmyB73, May 23, 2013.
  1. Maybe Knot
    Maybe Knot Member
    Nashville Tn
    Had the same problem with my Onan, Check the bridge rectifier, Simple and cheap fix.
  2. Thisisit
    Thisisit Member
    Midland, Ontario, Canada
    I may be late to the table but I had a frustrating issue as well. http://www.yachtforums.com/threads/kohler-7-5-r-generator-shutting-down.24973/
    rcrapps helped out with a schematic. Everyone with a Kohler 7.5R should carry spare, rough service fuses. There is a 10 amp and 2 amp in the board at the rear of the unit. My 2 amp fuse was burned out although it didn't look it. I confirmed it with an ohm meter. Runs perfectly now.
  3. babyc34
    babyc34 Member
    Redwood City
    Did you ever get the problem solved. Mine does the same thing. Even a Kohler authorized shop can't fix it.
