Click for Ocean Alexander Click for Burger Click for Westport Click for Northern Lights Click for Cross
Just above water line thru hulls
Discussion in 'Technical Discussion' started by Capt Ralph, Aug 7, 2015.
  1. Capt Ralph
    Smile when you type that.
  2. Caltexflanc
    Caltexflanc Senior Member
    North Carolina
    H 22.7f:
    f. The discharge location shall be above the waterline created by maximum conditions of the boat's loading, heel, trim and motion astern. EXCEPTION: The discharge may be located below the waterline if the discharge line is provided with a vented loop to prevent siphoning into the boat. A check valve shall not be used for this purpose
  3. Capt Ralph
    H 22. refers to under 50 Vdc, bilge pumps.
    Except for comments of a loop higher than the water line if a list is involved, Comments of list angles affecting the loop height, a discharge Located below the water line has not been mentioned in this thread.
    The OP (me) refers to A/C and shower sump discharge hardware.
    Anti siphon on an A/C line would not be an issue anyway.
    Seems shower sump kits come with a built in check valve already.
    Just don't count on or use Crappy hose.
  4. Caltexflanc
    North Carolina
    Re-read the definition of "waterline" in the rule above. That's the waterline that counts.
    Why would anti-siphon on an A/C line not be an issue? Because it flows back to the intake?
  5. Capt Ralph
    Yep.
    Hose failures not included in that comment, but failures can happen anywhere.
  6. Caltexflanc
    North Carolina
    So given all the hoses, piping and connections associated with an AC system, it wouldn't make sense NOT to have an anti-siphon loops(s).. now would it?
    As for sumps, again, the little valves are there to prevent backwash of water remaining in the discharge hose into the sump when the pump turns off, not as a replacement for an anti siphon loop. Check out the instruction manuals.
  7. dennismc
    dennismc Senior Member
    Vancouver BC
    The a/c pump a lot of times doesn't produce enough pressure to open them. Or if it does they restrict flow, so you usually avoid them on an a/c pump.
